average pricefor a 6.0 ls2 block
Old 06-16-2011, 11:27 AM
Floorman279's Avatar
Default average pricefor a 6.0 ls2 block
whats the average price rangefor a bare block that will need honing? also i wanna throw one in my 98 z28.......how easy will the swap be? are allmounts the same? these are 4 inch bores right? are they essentially just a 4 inch bore ls1?
Old 06-16-2011, 01:13 PM
5.3LJimmy's Avatar
The motor mounts are the same but you will need to use the LS2 valley cover, timing cover w/ cam sensor, cam sprocket(05-06 GTO original part), cam and knock sensor extension harnesses, and will need to drill and tap the block to move the knock sensors to the side of the block. You can get all of this stuff in one package(LS2 conversion package) from SDPC or TSP.
I can't tell you what the going rate for a used block is but I believe you can get a new one for around 1200 bucks.
Old 06-16-2011, 02:50 PM
why do i need to move the knock sensors
Old 06-16-2011, 03:01 PM
5.3LJimmy's Avatar
Because the LS2 block doesn't have a spot to mount them in the valley.
Old 06-16-2011, 03:12 PM
do i even need them?
Old 06-16-2011, 03:18 PM
5.3LJimmy's Avatar
If you drive on the street and run pump gas I would recommend keeping them.
Old 06-16-2011, 09:56 PM
fastsspr's Avatar
No matter what you need them!!!
They are sensor who detect knocking and that kills you engine
Old 06-17-2011, 05:40 AM
Lol but back in the 70s those cars didnt have any and some of them made it 100000 lol
Old 06-17-2011, 08:00 AM
5.3LJimmy's Avatar
Back in the 70's the engines had 8.5:1 compression, 150 horsepower, and real gas. For a race only application running a quality race fuel, which is way more consistent than what you get from the pump, the knock sensors can be deleted.
Old 06-17-2011, 08:30 AM
Gotta love that lead lol.....is lead good for a motor? As long as u have the proper valvetrain for it?
