Dart Heads excessive valve guide play?
Old 06-17-2011, 03:36 AM
lstvr's Avatar
Default Dart Heads excessive valve guide play?
Hi Guys,
My TVR has progressively got worse over a period of time, smoking on overun,
So i decided to change the valve guide seals this week, which i have done...
However 4-5 of the valves have too much play in them, i didnt measure but its plain to SEE..
It was a mixture of inlet and exhaust, and play is in a 360 degree plane, not elongated.
Has anyone else experienced this problem?
I will pull the heads of to rectify this over the winter, but summers are short over here so will continue to use them until they salt the roads!
I didnt look for this when i installed as they were new and fully built, and assumed they would be fine.
Old 06-17-2011, 04:04 AM
vettenuts's Avatar
This was an issue with Dart heads and several vendors stopped carrying them for this reason. One vendor I know of also said the guide centerline was not aligned with the valve seat center. Sounds like Dart had some QC issues. I had a very early set of Dart heads and they were overall very good. My oil consumption actually went down when I installed them. Seems like the QC worsened later compared to the set I had.
Do a search because if I remember correctly Brian Tooley made some measurements and found exactly what you did. There was also a major discussion on this on the hardcorels1 board but I don't think that board exists anymore.
Old 06-17-2011, 04:09 AM
lstvr's Avatar
Hmmm..
I see, i will stick with them i think, have the work done and go with some heavier porting, and possibly stick lighter 2.08 valves in.
Its that or spend a **** load more cash on something trick like All Pro's...
Old 06-17-2011, 04:24 AM
lstvr's Avatar
This is the problem!!!
Old 06-17-2011, 07:42 PM
S10xGN's Avatar
Can you "mike" the valve stems? LS valves are 8mm (0.3150") while old-school small-block Chevy valves are 5/16" (0.3125") for a difference of 0.0025". Possible the installer grabbed the wrong valves?
Old 06-18-2011, 07:33 AM
vettenuts's Avatar
A couple of people you can contact to get some information on this issue would be Ed Curtis at Flow Tech Induction or Bret Bauer at Bauer engines. They have both done quite a bit of work with Dart heads and Ed was getting bare heads to build a while back. Not sure he still using Dart products but he may be able to point you in the right direction. The valve stem diameter mentioned by S10xGN is also a quick check that could be made.
Old 06-18-2011, 03:18 PM
lstvr's Avatar
Problem is I am in the uk, so have to do the work here.
Old 06-19-2011, 07:52 AM
vettenuts's Avatar
Understand, but it might be worth an e-mail to them to see if they can provide any insight.
Where in the UK?
Old 06-19-2011, 11:58 AM
lstvr's Avatar
Birmingham, thats the second biggest city in the UK after London, Lots of engineering know how around here, where the UK's bikes and cars were made,sadly all gone to the wall...
If the wrong valves were fitted would the Collete not be ill fitting, and also valve length the same?
Old 06-19-2011, 05:24 PM
vettenuts's Avatar
I would think it would show some fitment issues.
My mom is originally from the UK which is why I had asked
