Identify what i found stuck to my drain plug magnet
Old 06-19-2011, 04:35 PM
b4cz2896's Avatar
Default Identify what i found stuck to my drain plug magnet
Like the title says. Doing the regular oil change on my car and found this stuck to the drain plug. No strange noises, normal oil pressure. Pulled the valve covers and don't see anything all the rockers look good and the springs, retainers, and seals look good. Maybe the blower bearings? Or maybe a lifter cup? Wristpin lock? 02 ss 67000 miles, ls2 chain, comp cams dual springs w/ titanium retainers, tr cheatr v3, vortech g trim... About 8k on this setup.
Old 06-19-2011, 04:44 PM
redbird555's Avatar
no pic???
Old 06-19-2011, 04:46 PM
parks450's Avatar
What exactly is "this". Kinda need something to go off of.
Old 06-19-2011, 04:47 PM
b4cz2896's Avatar
Updated with pic
Old 06-19-2011, 05:00 PM
slowside's Avatar
Put a ruler next to it? Figure out the radius or diameter however you can. I am a noob but what about spring seat??
Old 06-19-2011, 05:01 PM
zamora7's Avatar
Single edge razor blade
Old 06-19-2011, 05:35 PM
parks450's Avatar
Id say lifter cup retainer.
Old 06-19-2011, 06:10 PM
b4cz2896's Avatar
It's possibly a lifter cup retainer, but i would think it would be tapping at least. Guess I could remove the rockers and pushrods and look down the pushrod holes with a borescope.
Old 06-19-2011, 10:37 PM
garygnu's Avatar
also mite be a rocker trunnion bearing,how long is it?
Old 06-20-2011, 10:32 AM
b4cz2896's Avatar
I have a spare set of rockers so I placed
Old 06-20-2011, 10:34 AM
b4cz2896's Avatar
I have a spare set of rockers so I placed it along the bearing cap and it is an exact match as far as diameter, however I looked at the rockers in the car and don't see any missing bearings or the caps
Old 06-20-2011, 11:50 AM
Irish350's Avatar
^maybe you sucked one up through the g-trim??
still looks like a lifter cup to me.. could you see behind the last rockers on each side when you pulled the covers?
Old 06-20-2011, 12:55 PM
DONAIMIAN's Avatar
Looks like a piece of a bearing retainer from a rocker. You said all rockers are good so could be from the previous owner (if you're not the original)
Old 06-20-2011, 12:58 PM
DMM
DMM's Avatar
Do not have any idea what that may be, but how do you like the V3 cam with your supercharger?
Old 06-20-2011, 03:10 PM
b4cz2896's Avatar
Runs good, I used a mirror to check the rear rockers, but I think I may take all the rockers and pushrods out to check. I didn't have my torque wrench home so I didn't want to remove them yet. Car traps 127 with drag radials and stock exhaust besides a cutout.
Old 06-20-2011, 04:29 PM
BrntWS6's Avatar
Looks like a lifter cup to me too. There was a guy on here not to long ago that had a similar issue, ended up being a lifter, and his car was running fine also.
Old 06-21-2011, 12:41 AM
chrisfrost's Avatar
Looks to me like the size and shape of a lifter roller bearing on the cam end or a trunion cap . Good luck
Old 06-22-2011, 07:56 PM
b4cz2896's Avatar
So let's take a poll should I drive it till it blows or pull the heads to inspect the lifters lol
Old 07-05-2011, 03:05 PM
b4cz2896's Avatar
Quick update, did a leak down test and found excessive leakage on cylinder 7. Air coming out of valve covers going to pull the motor this weekend.
Old 07-05-2011, 09:53 PM
remauto1187's Avatar
Looks like to me it can only be one of 3 things. Lifter cup retainer, trunion bearing retainer or piston circlip (the old style of course).
+1 on the guy mentioned earlier that had the same problem and his parts looked alot like yours. It was a lifter getting ready to destruct.
