Cam Only 120+ traps possible? setup?
I'm in the middle of a cam search for my car. I'm not looking for dyno numbers, that doesnt matter to me. I'd like to go off of MPH instead. So that being said, is there a cam only setup i can go with that will trap 120mph+?
car/mods:
02 z28 m6 (full weight) would like to keep it that way minus spare/jack
ls7 clutch
slp 1 3/4 long tubes
slp y
gutted cats
ported TB
slp lid
SSRA
powerbond udp
3.42 gears but am changing to 4.10's or 4.30's depending on cam powerband
stock wheels w/ bfg g force DR's
and i've got a set of Lunati dual golds ready to go in and ls7 lifters
i'd like to go with a cam motion grind, specifically a 232/236 .629/.629 113+4 power range is 2400-6400. But im open to other suggestions since i havent seen many track or dyno numbers from cammotion LS cars.
car/mods:
ls7 clutch
slp y
gutted cats
ported TB
slp lid
SSRA
powerbond udp
My TA trapped 118 full weight with a TR230, dynatech headers, stock pulley, and stock LS1 intake. You should be able to reach that goal with that cam and some weight reduction. If you are talking about 3.42 gears in the stock rear don't waste any money on a gear swap. Save it and put it towards a 12 bolt or 9".
I'm running a Cam Motion and its done great so far.
As for trapping 120+ in a cam only car, it would take a well thought out combo. It won't ET with a 10 bolt though because you can't launch hard.
My car weighs 3360 w/o me. Barely any weight reduction and I even have a 9", with a fabricated housing. Only things removed: spare tire/jack, abs, EGR, AIR, rear seats, and various items like small heat shields and such from engine bay. It's not too hard to drop a couple hundred pounds from these things and still be a very comfortable car on the street.
