oil pressure help please, new block
ok i just built a brand new gm 6.0 cast block lq9 and have very low oil pressure, pick up o ring is good the pump was good on my other motor.Im thinking since it was a new block i make be missing a oil plug in the block some where. Cause i had to put all of the water plugs in it. Does any one know if the are any oil plugs in the block? I put the little plastic one in the back but thats it. Thanks,Jason
There is also a hole in the front of the block in the same place the plastic one goes in the rear. Sometimes new blocks wont come with the plug installed. It looks like a small freeze plug.
Make sure that one is there as well.
LS1Tech Premium Sponsor
I believe you're looking for GM part number 9427693. We have them in stock or you can typically grab them at any decent GM parts house for a few bucks.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
yeah, without that plug it would pretty much be zero.
I know because I know a guy who is a self perscribed LSx expert who built a motor once and failed to install that plug. Guess he doesnt know quite what he claims huh?
lol
lol
glad you found it before any damage was done.
