arp ls1 head bolts
arp ls1 head bolts
just go a question have a 01 trans am ws6 ls1 going to do head and cam bought most stuff. does my car have all the same lenght head bolts or the set with 3 different sizes. witch ones does my car have? what the arp part nuber so i can get the right ones thanks for the help. is arp 134-3609 the right set thanks
LS1Tech Premium Sponsor
134-3609 will do the trick, but as a warning, it is VERY difficult to find any of them right now with a nasty back-order ARP has on them. We've been out for months and ARP cannot even give us a decent ETA on them right now
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
there is a backorder for a while can i use gm perfomance 12498545 head bolts insted. are these the correct kind dor my car and are they torque to yeild. no reusable. do i have to torque angle them with the gauge. or should i just wait for arps. thanks.
The following users liked this post:
Blac94z28 (04-27-2020)
Yes, 12498545 will work perfectly. They are torque to yield like you said and not re-useable.
__________________
i have to use the torqe angle meter on these . its a tight engine bay is there enough romm to torque angle them under the hood? i like the arp because there is no need to put torqe angle gauge on them makes it easyer.
If the studs aren't on backorder, I recommend going with them. I tried to save a few bucks and use the ARP bolts (didn't want to do TTY again) but regret it. The studs shorten the time to remove the heads as you won't have to meticulously clean coolant out of the block bolt holes again. Also they won't beat up the block threads with constant torqueing/retorquing.
your taking about head studs not head bolts? th thught it wasent posible to put head studs on a ls1 trans am with motor in car. can i put jead studs in the block in car and be able to get cyl heads on the block? i thought it wasent possible to do this because there is little room in f body but if i can i will what is the cost for a arp head stud kit anyway i gess arp would give torqe specs and sequence in package thanks for help.
They are off back-order now and everyone has them in stock that wants them
__________________
The way ARP has been lately, they could be back-ordered again very soon!
__________________
