Anyone Running MTI 5.3 Stage 2 Heads?
I am still pondering the Cam and Heads and what to run?,seems how Bigger cubes are not in the near future.I will have this Combo for a few years,so I want to do it up good without spending lots of doe,I dont have Do you like em?How much RW HP and RW TQ are you seeing from these Heads?What are your ET's and Traps?Please let me know,I need all the help I cant get
T.I.A.
T.I.A.
I run there S2 heads with X1 cam. I love it! I have A4 and she is tuned for spray-rich and alittle timing pulled and I still pulled good numbers. As you can see I have 12-bolt and all. Car runs strong, A/C, power everything. I drive this car everyday with no problems. You just got to tune it with the X1-big cam!!!Check Sig!
I have a set of MTI 5.7 heads and used to have a 224/228 cam and the car ran consistant 11.4s at full weight. I now have the g5x2 cam and the rest of the bolt ons so im shooting for a 10.X since the car is also lighter now.
1 Post
You'd be in very good company if you choose the MTI 5.3 heads. I should know I used to have a set along with the C1 cam (222/222 on 112), in my 3,520 lb Z28 and ran 120 mph trap speeds, my ET was an 11.9 on drag radials with the 7.5 rear end. My old heads/cam combo. is now on the fastest stock bottom end LS1 in the country. Mike P. at MTI has run a 9.69 @ 135 mph with a 250 shot using my old stuff.
Thanks
Originally Posted by M6HuggerSS
anyone gpt any pics of there MTI 5.3 heads?
and whats the CR with those heads....10,8:1...???
LS1Tech Co-Founder
The price isn't bad on those 5.3L MTI heads either, they are offering them for only $1795 without core charge right now. Thats cheap for a badass set of hand-ported heads with top of the line components. Then when you get them you can sell your stock LS1 heads for $200-300 and end up with a $1500 set of Stage 2 heads
Originally Posted by Ben01C5
Any dyno numbers with the 5.7's and the G5X-2? I have the same cam and am looking for the right heads.
Thanks
Thanks
