Narrowed down to 2 cams, need input from here...
here are the specs from thunder racing:
#1) TR TruTorq Cam Level 2 - 223/230 .609/.604 115 LSA 1800-6500 rpm power band
#2) TR TruTorq Cam Level 4 - 227/234 .616/.614 115 LSA 2200-6500 rpm power band
I have 2000 LS1 M6. Going with 4.10 gears, Monster stage 2 clutch, Hooker 1 3/4" LT headers, Hooker ORY pipe, and the Flowmaster exhaust on it now. Staying NA for now with stock 241 heads. Might upgrade to 243 heads one day but that is not for sure. I am kind of looking for a happy medium in all categories here. I want a choppy idle, but want some good power and torque. It is not a DD so a little loss in drivability is not a big deal to me.
From what I have researched, the Level 4 cam leaves my intake/exhaust valves open a little longer, but I lose 400 rpm off my power band. I won't be drag racing this much, maybe 2-3 test and tunes each year at the local strip but that is it.
ditto on the torquer v2 but i would go with a 112lsa it will bring your power in a little sooner. it will also have a nice choppy idle. personally i think you should really give texas speed a call and get their recommendation on a cam for what you are looking to do with the car.
Given that I am a newbie to cams, I may be looking at the wrong ones. I looked up the Torquer V2. Specs are 232/234 .595"/.598" 112LSA
It looks like I longer duration with the V2 while staying under .600" which I have heard is better to do. But what kind of torque can I get out of this cam especially at a lower rpm range. I definitely want the "put you in the back of your seat" feeling. But want to maximize my power as much as possible.
Thanks for all the input. I have checked out some cams you guys suggested. Spoke to TS today and was pointed in the direction of the V3 instead of the V2 with a 111LSA. Will let you guys know what I will go with after I look up some more info on other cams.
I would stay away from LSK lobes (TV3 intake) on a DD car. Too harsh and unnecessary.
Thanks for all the help guys!!! I have my decision narrowed down to option 2. I am still considering the Torquer V3 (231/234 .643"/.598" 111LSA) from Texas Speed. I like the duration numbers a little better on the TruTorque Lvl 4. But I LOVE the LSA on the V3, plus it seems it'd be a little more torquier.
