Best Heads for a 408 ci
Old 09-07-2011, 12:20 PM
oakley6575's Avatar
Default Best Heads for a 408 ci
Hey guys, so this summer I got my 408 built and its in my truck. Turned out good and runs solid without any issues. Here are the specs:
408ci LQ4 Short block
Callies 4" crank and 6.125" rods
Wiseco flat top 11.5 compression pistons
Stock LS3 Heads
Stock LS3 intake
231/239 114+2
With this combo through a 4L80e Silverado, it made 434whp and 400wftlb. Good not great... I would think the torque numbers would be a little higher but it runs strong. Obviously the H/C/I combo is really holding this project back.
I want to get everyones opinion on a cylinder head that will wake the numbers up.
Old 09-07-2011, 12:32 PM
Duffster's Avatar
L92...
Old 09-07-2011, 01:00 PM
oakley6575's Avatar
Originally Posted by Duffster
L92...
? Did you read my post? I have LS3 heads on there right now.
Old 09-07-2011, 02:15 PM
01ssreda4's Avatar
Something/anything ported. That motor wants to breathe.
Old 09-07-2011, 04:49 PM
PREDATOR-Z's Avatar
TFS or AFR
Old 09-07-2011, 08:04 PM
oakley6575's Avatar
How big of a runner could I run. This is a daily driver. But I don't want to leave power on the table. Is 235cc too big? 225cc?
Old 09-07-2011, 08:09 PM
Lambert695's Avatar
AFR 215cc and a Fast intake. as stated above... that motor wants to breathe!
Old 09-07-2011, 08:11 PM
JS01's Avatar
The new AFR 230's or TFS 235's would be nice. Almost any of the MAST deals too. Put a FAST LSXrt on there too.
Old 09-07-2011, 08:16 PM
oakley6575's Avatar
Yea when I get heads, I will for sure get a fast intake and cam to match. Any ideas how much horsepower/torque AFR 230's Fast intake would produce.
Old 09-07-2011, 08:17 PM
studderin's Avatar
Mozes
Old 09-07-2011, 09:27 PM
Jim85IROC's Avatar
I don't think heads are your problem. Stock LS3s with similar cams are putting down way more power. LS3 heads on a 408 should be a 500RWHP combo.
Old 09-07-2011, 09:32 PM
oakley6575's Avatar
Yes, through an m6. 4L80e's are extremely robbing. I figure I'm making around 550 at the crank. Right where it should be with stock heads/intake and a small cam.
Also the tuner didn't spend much time on it. I was pretty disappointed. He didn't tune for different injectors or anything like that. I think he only played with the VE table and timing. So i'm trying to learn the tuning part of this motor as we speak.
Old 09-07-2011, 10:43 PM
Duffster's Avatar
If you don't like your heads... when you get more, wanna sell them to me?
Old 09-08-2011, 12:17 AM
HTX
HTX's Avatar
AFR if you have a good budget.
Old 09-08-2011, 04:15 AM
KRAZY K 2000 TA's Avatar
AFR heads and fast intake and throttle body,GOOD tune!!
Old 09-08-2011, 07:19 AM
reeperz28's Avatar
Send your heads to advanced induction im sure he can fix you up with a cam too.
Old 09-08-2011, 09:14 AM
SOMbitch's Avatar
Yes there are better heads but your problem is not with your heads. Get it tuned correctly first and see where you are. I have seen a good tune pick up 30+. Also what exhaust are you running and are you sure lifter preload is correct? Unless you are just on a stingy dyno those #'s are pretty low. My old 346 made those exact #'s on a smaller cam.....
Old 09-08-2011, 09:52 AM
Detoxx03's Avatar
First off I thnk your cam is too small for a 408 but for heads I would go with some TFS 235's. If you don't have a FAST intake you should look into that too
Old 09-08-2011, 09:59 AM
OldCobraGuy's Avatar
At your altitude and air, and being in a truck, you need grunt (torque)...not just hp. The best way to create that is with velocity through the intake tract. I'll bet you that AFR would recommend their 205 cc heads. I would be shocked if there was a significant drop in top end, but the bottom end would be a bunch better due to the increased velocity through the intake ports. This is assuming you have good headers and exhaust. I have a lot of experience running at 4500 to 6000 feet in elevation. This will help. You may be nowhere near that elevation, but in Las Vegas, I can guarantee the density altitude will be way up there most days.
Old 09-08-2011, 11:47 AM
oakley6575's Avatar
Yea thats funny, those were my exact numbers. I was trying to run 1.875" headers and they didn't fit my truck so I had to overnight some replacements. They only thing they had were Pacesetter 1.75". From there I'm running 3" to a dual inlet Magnaflow, and a single 4" out.
Obviously I need to buy a wideband and tune the truck myself.
Quick Reply: Best Heads for a 408 ci
