Please help!! Missing over 50rwhp after G5X3/LSX intake install! Dyno graph inside.
We can't figure out what the heck could be wrong. I'm making way less power than I did with a much smaller TR230/224 cam, LS6 intake, stock waterpump, and stock YT rockers.
I've recently added the G5X3 cam, Meziere EWP, and port matched LSX intake.
My dyno graph shows something is definately wrong. The graph looks like a seismegraph, not a dyno graph....and this is after maximum smoothing!! I stop gaining torque at 3800rpms....it stays flat all the way until 6200rpms. I should keep gaining torque easy up to 4800+rpms.
My car should be making way more horsepower than it is. Louis of LG thinks it could be a bad MAF sensor based on the symptoms I've described. My A/F is perfect, no knock retard or detonation, plugs look perfect, and no stumbling except the car has a tougher time idling with the G5X3 vs. the TR230. Ignore the A/F spike at 6000+rpms, that was the o2 sniffer falling out of the exhaust.
I did just have 7 bent valves replaced and my heads milled because they were slightly warped. The heads were fully tested and are said to be in great shape.
a/f looks good. graph looks like ***. Hows it feel on the street though? Did you take off those 5.3s or no?
theres definitly no reason for it to idle so bad...Mikes is fine. You have a different lsa?
Originally Posted by Todd@DiscountTireDirect
sheesh..whats goin on verbs????
It drives fine other than the fact that it hunts for idle a lot more than it used to, its just way down on power.
Don't forget I have an aluminum flywheel which sucks for making big cams idle, and this is on a 112 LSA not the 114LSA you're used to.
I can shift faster than you.
Does the car make a clean pull on the dyno (sound normal,etc.)?
The 6400+ range is definitely your valvetrain. I have yet to have any good results with the Yella Terras for setups trying to turn any kind of RPM past 6500.
Originally Posted by 66ImpalaLT1
Anyway, did you log your dyno pulls with Autotap or EFIlive?
I'd be interested to see the MAF GM/sec and Frequency from one of your pulls. Can you get them to export a log file and email it to you?
I would check the obvious first (bad sensors,etc.) If those check out good, I would look REAL close at your valvetrain.
Also, I have 7.35 pushrods on the exhaust, with 7.4 pushrods on the intake. This was done because my intake and exhaust preloads were off by about .020" and since the YT rockers are connected, I couldn't shim the exhaust side more than the intake or else I'd have cockeyed rockers. Maybe the different length pushrods or lifter preload are places to look at.
Do you think it might have to do with your problems with the LSX intake or maybe the port job? Switching the intakes again would answer that question. It could also be like SSOnYourSix said- an installation problem with the cam being degreed wrong. Or it could be that the bent valves maybe messed something else up. I hope you get it figured out and its a cheap and easy fix.
