02 WS6:AFR heads and stock rockers?
Old 09-07-2011, 09:50 PM
02-ws6-6speed's Avatar
Default 02 WS6:AFR heads and stock rockers?
can i use stock rockers and a set of afr215 mongoose heads?
running 231/234 cam lsa111 w/.644 lift, fast 102mm intake and throttle body and need to get a MAF Sensor. any suggestions
Old 09-07-2011, 09:55 PM
Brad Hutchcraft's Avatar
Yeah, you can use your stock rockers.
Old 09-07-2011, 09:59 PM
Sommer86's Avatar
I am. But I did the Comp. Trunion upgrade to my stock rockers. Oh, and I'm running AFR 230's.
Old 09-08-2011, 01:17 AM
Mike94ZLT1's Avatar
Will they work? Yes. Is it a good idea? No. AFR heads, unless you specifically order them with OEM style valve guides, have bronze ones. Without a full roller rocker they will wear much faster.
Old 09-08-2011, 01:48 AM
01ssreda4's Avatar
I'd use a roller tipped rocker arm if it was me.
Old 09-08-2011, 12:39 PM
Rise of the Phoenix's Avatar
Off topic, but that sounds like a great setup you'll be running. Make sure to post up numbers once it's all said and done.
Old 09-08-2011, 05:08 PM
Sommer86's Avatar
Hey Mike, define "much".
Old 09-08-2011, 09:20 PM
I also bought a racetronix fuel pump and power harness. Anyone have install tips for this setup? Have 42lb injectors also.
Old 09-10-2011, 07:28 AM
vettenuts's Avatar
You will have noticable wear in 10K miles (valves will wiggle).
Old 09-10-2011, 09:11 AM
SpinsB's Avatar
you will b very pleased with this product. I just put mine in this past week, not hard todo just took some time but pretty straight forward.
Old 09-10-2011, 07:25 PM
SpinsB: Did you cut a trap door or remove all suspension in rear?
Quick Reply: 02 WS6:AFR heads and stock rockers?
