How do you get carbon off heads and pistons?
Old 09-22-2011, 06:13 PM
sjsingle1's Avatar
Default How do you get carbon off heads and pistons?
a search did not turn up much............whats the best way.........or your fav way to do it?
Old 09-22-2011, 06:29 PM
CustomX's Avatar
Leave it, it bumps up the compression
Old 09-22-2011, 06:35 PM
sjsingle1's Avatar
kewl.......14.5 ratio ought to give me a extra 5 horses
Old 09-22-2011, 06:50 PM
Deviant LS1's Avatar
Scotchbrite pad and brake parts cleaner.
Old 09-22-2011, 06:52 PM
CustomX's Avatar
But on a serious note, what the guy above me said is what I did (I used carb/choke cleaner but same stuff basically). Just make sure to get all the grit out of the cylinders afterwards. Air gun works great for that.
Old 09-22-2011, 07:01 PM
got milk??'s Avatar
White Roloc disc and a 90" angle grinder/power drill is the fastest.
Old 09-22-2011, 11:05 PM
sjsingle1's Avatar
where do ya get those discs?
Old 09-22-2011, 11:09 PM
99 WS-sick's Avatar
harbor freight is the cheapest place to get them discs but be carful not to drind on it to long or u will take away some metal which will EF your heads up. we use a wire brush on a air tool and lightly remove the carbon, it takes like 5 mins or so then wipe every off and blow off with air nozzle
Old 09-22-2011, 11:15 PM
01ssreda4's Avatar
Motor in or out of the car?
Old 09-22-2011, 11:19 PM
sjsingle1's Avatar
in car
Old 09-22-2011, 11:25 PM
01ssreda4's Avatar
Angle grinder, pneumatic, and a 2 inch roloc disk made for gasket removal.
Old 09-22-2011, 11:33 PM
sjsingle1's Avatar
guess its harbor freight for me tomorrow
Old 09-23-2011, 02:01 PM
VandykeT/A's Avatar
If you don't want to sand any sit a head back on it and fill it full of seafoam and let it sit.
Old 09-23-2011, 02:41 PM
PIMP_2's Avatar
A 250 shot will help
Old 09-23-2011, 04:13 PM
O2Form's Avatar
Why bother seriously? Its just going to come back.
Old 09-23-2011, 04:22 PM
01ssreda4's Avatar
Seriously....it makes you feel better.
Old 09-23-2011, 05:20 PM
O2Form's Avatar
Thats about it..........best way to keep it spotless is to run something like Lucas fuel system treatment every tank full of gas. I've tried it and it does keep the internals spotless.
Old 09-23-2011, 06:00 PM
BobDoLe's Avatar
Beat me to it.
+1 for nitrous
Seafoam is for pansies
Old 09-23-2011, 06:47 PM
s346k's Avatar
really though you can safely run a 100 on it and it will clean that **** up better than new.
Old 09-23-2011, 11:08 PM
BrntWS6's Avatar
I used those Roloc disks to clean off the old gasket material for my H/C swap and they work great! Just make sure to tape up everything you don't want that **** getting into, because it gets everywhere!
Quick Reply: How do you get carbon off heads and pistons?
