Whos has put milled 317's on a ls1??
Old 10-26-2011, 02:24 PM
MIKELMOTORCYCLE3398's Avatar
Default Whos has put milled 317's on a ls1??
Need to know if u had any valve clearance issues with them. Please, someone who has actually done it. The heads are milled 30 thousandths and valve ground
Old 10-26-2011, 02:44 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
There are tons of folks with 317's on LS1 short-blocks. What are you wanting to know? If it's piston to valve clearance you're looking for, it'll be virtually identical to an LS1 head milled .030". You can clear about a 230º @ .050" intake lobe without flycutting, assuming you still have true flat-top pistons.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 10-26-2011, 07:25 PM
I have a 236/242 duration 112lsa
Old 10-26-2011, 07:42 PM
I guess i may have a problem. Errrr
Old 10-27-2011, 08:03 AM
redtan's Avatar
People usually get 317s for their bigger combustion chambers to lower compression. Instead of getting big chamber 317s and milling them for a smaller chamber why not get some stock 243s and be done with it?
Old 10-27-2011, 09:35 AM
I agree, an LS6 head would be the better choice with a relatively large camshaft. The extra compression will be a welcomed addition for an NA or nitrous combo!
__________________
Old 10-27-2011, 08:09 PM
Well. They were 150 bucks. And im on a budget, What can i do to make this setup work?? Thicker head gasket?? How do i flycut??
Old 10-27-2011, 08:12 PM
What about some 5.3 heads?? 243's arent cheap. And i might be able to swap for some 5.3. But thwy dont flow like 243's at all. . 317's do. And id like to keep near stock compression. Thats y i got milled 317's. So the p2v clearance wont work??
