Do 317 hrads on a stock bore ls1 require a 6.0L head gsaket??
LS1Tech Premium Sponsor
That being said, you do need to run the larger bore gasket for the 317 heads on an LS1, because those chambers are wide!
http://www.texas-speed.com/p-206-gm-...ad-gasket.aspx
Those would work great!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
