Results from compresssion check. What do the # mean?
Old 03-14-2004, 06:57 AM
Black Sunshine/ 00SS's Avatar
Default Results from compresssion check. What do the # mean?
1- 185 2- 190
3- 185 4- 180
5- 170 6- 170
7- 185 8- 185
Leakdown test came out good, with no bad leaks. Are the # provided good, bad?
Old 03-14-2004, 07:14 AM
evil02z's Avatar
Usually if the cylinders are withing 10-15% of the lowest cylinder you are OK. Anything below 90psi is considered a dead cylinder.
Old 03-14-2004, 07:15 AM
99 red Z's Avatar
I did a compression check, my highest number was 190. manual says as long as they're above 100 and max difference between the highest and lowest is 25%.
1- 170
2- 165
3- 175
4- 180
5- 190
6- 185
7- 180
8- 165
I bent a couple items though
Old 03-14-2004, 07:25 AM
Looks like all is well then. Time for a 300 shot
Old 08-20-2011, 01:03 PM
NevaslowLs1's Avatar
how do you fix a dead cylinder
Old 08-20-2011, 01:07 PM
Restricted User
z99ls1's Avatar
Usually means you either have a valve leaking, bad rings, or another head problem.
Old 08-21-2011, 11:23 AM
Lt1Porsche's Avatar
Numbers appear fine to me. Sometimes you can get a little bit of a low reading 10-20 psi in a cylinder stickly due to fuel. Sometimes I like to put a very little bit of oil in the cylinder if i get a slightly low reading and see if it comes up. 90% of the time if does. The oil helps seal the ring a little better. But honestly your numbers look fine. Id say shes good to run.
Old 08-21-2011, 11:25 AM
Lt1Porsche's Avatar
A "DEAD" cylinder is caused by another issue like stated above. Bad valve, bad rings, cracked piston, head gasket, etc
Old 08-22-2011, 11:07 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Also checking with a warm engine makes a world of difference!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 08-22-2011, 11:34 AM
remauto1187's Avatar
A typical scenario if your numbers were not anywhere in spec would be to add oil to the lower PSI cylinders and if their PSI came up then that would mean that the rings were worn and the engine would need a rebuild (Atleast reringed). If the numbers did not come up then you have a head gasket leak or valve leakage. To isolate that you would put a air fitting in each cylinder and blow compressed air into each cylinder and see if you get bubbles in the coolant system (look in filler neck of radiator), if you do then you have a cracked water jacked, cracked head or leaking head gasket. If no air bubbles in the cooling system then you most likely have heads that need a valve job.
