Is a little smoke normal from oil filler neck?
Old 12-28-2011, 11:04 AM
xhifer's Avatar
Default Is a little smoke normal from oil filler neck?
I have a 02 z28. When I check my oil after turning off the car at normal operating temperatures (180-185) there's little smoke coming out of the dip stick hole and when I take off the oil cap, there's also a little bit of smoke. The oil cap has some oil gunk build up as well. Is this normal?
Old 12-28-2011, 11:24 AM
parks450's Avatar
Yes, most vehicles I have seen all do it, even brand new ones.
Old 12-28-2011, 11:26 AM
xhifer's Avatar
Thats good to hear. I'm just afraid my rings are done. Is there another way to test other than a leak down test?
Old 12-28-2011, 11:36 AM
NVR_SPDS's Avatar
Yeah, its normal. If im not mistaken, its not actually smoke, but oil mist.
You can also do a compression test which will help give you an idea if there is a problem.
Old 12-28-2011, 11:44 AM
xhifer's Avatar
Shouldn't all the mist or smoke escape through the PCV valve?
Old 12-28-2011, 11:55 AM
chaman's Avatar
Of course...when the oil cap its in place.
Old 12-28-2011, 11:57 AM
NVR_SPDS's Avatar
^^ LOL
Once you turn off the car, there is no vacuum to pull the mist in to the pcv system.
Old 12-28-2011, 11:58 AM
xhifer's Avatar
Lol I guess I don't have to worry for now
Oh, I also hear a hissing when driving..
Might be off topic but When I'm at a stop light, my car has a little intermittent shake and a roooooom rooooom noise.
Old 12-28-2011, 03:29 PM
jaxcam02's Avatar
I use to be worried about that when i first got my car. But its remained constant and I assume its just how the ls1s feel. when I'm in neutral my car will feel like its vibrating consistently for a half second with about 1 to 2 seconds between the "vibrating" feeling. i think this is what you are talking about but if thats not what your trying to describe then hopefully someone can help you out.
Old 12-28-2011, 05:52 PM
xhifer's Avatar
It pretty much is what you've described.
Old 12-28-2011, 07:41 PM
NemeSS's Avatar
Common traits of hi mile aluminum block ls1s. I've seen motors built by shops that the oil fill neck looks like a lil train smoke stack
The truck iron blocks do not have that issue. My 330k mile dd 4.8 does not smoke or any of the above issues.
I think it's just the aluminum blocks that do this.
Old 12-28-2011, 08:33 PM
jaxcam02's Avatar
yea my filler neck is encrusted with that **** i try to clean it out every oil change, but its hard to get out without letting it fall back into the block lol
Old 12-28-2011, 10:05 PM
xhifer's Avatar
I guess my rings are at least still okay. I revved the motor with the cap off and felt for air pushing out or puffs of smokes. I had none, so that relieves me a little.
Quick Reply: Is a little smoke normal from oil filler neck?
