valve size on 5.3 heads want to go bigger
what is the largest intake and exhaust valves you can put in a 862 head? I want to go bigger on both intake and exhaust but dont want to change out seats. any input is welcome!
I would run ls6 heads because you won't those that much compression and you will get bigger ports as well as bigger valves, especially on an ls1 bore...the heads are like 350....compared to the prob the same price for new valves and valve job...that's how I look at it anyways
I was always told not to touch the exhaust valves. I have a 402ci LS2 in my car with some TFS215cnc heads opened up to 4" bore. We also did a valve job on the heads and installed bigger intake valves. My TFS heads came with 2.040 intake valves and we installed 2.055 intake valves but kept the exhaust valves the stock size.
Remember you can always lean on the cam to get the air in the motor to rather than installing bigger valves which is why I have a 246/255-607-632@113+2LSA cam. Car runs like a top and has gone 10.39@129mph full weight first pass right off the trailer. 3540lbs race weight.
There is still more left in my setup once my motor loosens up some and I get the anti sway on the back..
yeah. the ls6 heads are a lil pricey for what im doing. this motor is going in my nitrous gto. 241s are cheap and I plan on having them ported and completely rebuilt. imo ls6s arent worth the extra cash right now. next year I will be building a 4xx ci motor and ill go all out on the heads for that motor.
does anybody know the intake and exhaust runner cc difference between the 241 and 862 heads? I know the intake cc on a 241 is 200cc but im not sure the 862 is that big...
The LS heads are not all the same ,,,,,,,,,,,,,but the 862's and the 706's are 200cc intake runners also with 70cc exhaust runners ,,,,,,,,,,,if You look at the stickies up top of this forum alot of the heads and runner sizes and combustion chamber sizes are listed . Think about the valve seat for a second ,,,,,,say You put a 4" valve with same seat how would it flow,,,,,,,,,,,the same as with the smaller valve with more shrouding ,,,,,,,,the inner diameter of the valve seat is the restricting force .
