I need More power !
Old 01-15-2012, 11:08 PM
Import killa's Avatar
Exclamation I need More power !
alright well my car is pretty much stock its a
00 z28
loudmouth 2, slp air lid, ORY, Diablo predator tuner.
ran 12.9 @ 112 last summer.
i want more power but dont want to do any heavy mods. no H/C/I or headers. i was told i just do like after market suspension? torque arms contorl arms, subframe connectors, swaybars. I just dont know what will really make a difference. Im thinking about do a throttle body. Not sure if im gonna do it
Old 01-15-2012, 11:14 PM
sepsis's Avatar
N2o..
Old 01-15-2012, 11:16 PM
WhiteKnight '01's Avatar
A larger throttle body or at the least a P&P TB will give you a few extra horsepower.
Since you have an LS1 from before 2001, you have the LS1 intake instead of the LS6 intake. Add the LS6 intake and get it retuned, you should pick up at least 10-15HP from that alone.
Is your car A4 or M6? If you have an auto a stall would help and a shift kit.
I wouldn't worry about sub-frame connectors, not until your car starts making some serious power.
09camaro383's Avatar
If yo don't want to do anything more to the engine how do you want get more power
Old 01-15-2012, 11:18 PM
need2speed94's Avatar
00 z28
The strock throttle body isn't too shabby, I say go for a new intake and a set of headers. Since you have an 00' LS1, an LS6 intake is a nice bolton that's good for ~15whp, if not more when your setup becomes more complex. Pickup a pair of longtubes an you should pickup ~20-30whp. As for those suspension recommendations, go for it. I say go with lower control arms and subframe connectors for now. The suspension mods might not stand out too much right now, but will definitely be be well worth the money in the future when you're making more power and having trouble launching. Are you M6 or A4?
Basic maintenance might help you recover some lost HP depending on the mileage of the car. Run some engine cleaner through it, check all the spark plugs, make sure you have a clean fuel filter, make sure your MAF is clean, make sure your air filter is clean.
Old 01-15-2012, 11:19 PM
Good tips, but read the OP's post. He said no heavy mods, no headers.
Old 01-15-2012, 11:20 PM
Only thing you can do is bolts on looks like you have the ones that will give you the most power
Old 01-15-2012, 11:21 PM
Ahh, didn't see that he said no headers. Although since he's already got headerback aftermarket exhaust why not, Maybe he'll change his mind...
Old 01-15-2012, 11:24 PM
its an A4 i was thinking about a shift kit but wasn't sure.
Old 01-15-2012, 11:28 PM
Ahh, if you don't consider a stall a big mod, look into a stall. Helps a ton off the line. Maybe a baby stall like 2800 for now since your mods aren't too serious yet?
Old 01-15-2012, 11:34 PM
yeah im looking into them now. but i think im gonna do 80mm throttle body first and 3.73 gears??
Is this a good deal on a throttle body?
http://marylandspeed.com/professiona...726-p-836.html
Old 01-15-2012, 11:39 PM
I say if you are going to go with a new throttle body, go all out and go with a 90mm or larger. 90mm is a very decent sized TB. And as for gears, I thought about that too for my Z... but it'd be much smarter to get a better rear end first, then gear it (eww 10 bolt)... although with an auto and a baby stall like 2800 you probably won't have to worry about the rear like me, I'm M6 on some Nitto's. Have you thought about a new rear end at all?
Old 01-15-2012, 11:43 PM
well not really but my friend just popped his rear in his SS last night lol. But no i havnt really thought about that and i know 10 bolts...
Old 01-15-2012, 11:44 PM
wildcamaro's Avatar
a new throttle body is useless without a bigger intake (ls6)...the only way you are going to get more power is through all the mods you dont wanna do...so if all you care about is quarter mile time than yo dont need more power, you just need a stall (real good idea!), some subframe connectors, lower control arms with relocation brackets, aftermarket torque arm, some sticky tires like mickey thompson et streets, and some gears (like 3.73 or 4.11)...those are the only other ways you will pick up time other than learning to be a better driver as far as drag racing goes (timing the lights perfect, doing good burnout with correct tire psi, staging correct, things like that)...anyway good luck man...12.9 is pretty good considering you have almost no mods...keep it up and dust a few stangs lol!
Old 01-15-2012, 11:46 PM
That's too bad :/ I'm dreading when mine will finally give up on me. Spending $1200 isn't something anyone is anxious about hah. What kind of tire you have on it right now? If you run street tires and plan on going with a small stall I wouldn't worry and just pick up 3.73s. If you're gonna run DRs or slicks then maybe a new rear would be smarter before gears.
Old 01-16-2012, 02:11 PM
Captain Double Post
BOBS99SS's Avatar
No heavy mods no big power the end
Old 01-16-2012, 02:15 PM
wildcamaro's Avatar
Agreed^^^^^
Old 01-16-2012, 02:41 PM
I forgot to add, a cutout is a nice mod for $200 that'll open up your exhaust a bit and give you 5-10hwp. And you open it up only when you need it so those ******** cops won't get you for having a loud exhaust.
Old 01-16-2012, 03:11 PM
gs462's Avatar
You need to work on the suspension, 112 mph is LOW 12 high 11 second MPH
what was your 60 ft on that run??
