Ultimate 6.0 street head?
Hey guys,
I'm lookin or some advice and diretion on heads. I need to know how much is too much and how I can get the best power under the curve for my current set up. My Mods are in my sig, but I'll give a quick run down:
I have a 90mm truck intake manifold and 87mm TB
EPS 222/226 on a 114 +4 with about .600 lift on both sides
1 7/8" catless ARH
Currently running a 3" cat back, but I may be switching to a single 3.5" with a cut out.
I currently shift at 6300 RPM and I just want to make as much power as possible with that in mind. I have seen some decent deals on patriot stage 3 243's, but i dont want to make sacrifices on such a key part to making NA power. The problem with most cnc'd 243's is the intake runner is jacked up to about 225-230cc which I think may deliver more power at the cost of low end torque. I know in the big scheme of things thats fairly small, but as I said I just want as much power everywhere as I can get on a decent budget. I'm not revving this thing to the moon like some of you. I have seen impressive results on this forum from AI's cnc'd 243's (about 50 HP over untouched 243's) with a cam similar to mine (224/228 on a 113) that pulled to 6500.
I think my biggest fear here is that I will pony up for heads but then not see most of what I would have gained from them by not having a more aggressive cam and shift points. Is that something I should be worried about?
Can a cnc'd stock casting like what is offered from WCCH or AI compare to the small port offerings from TFS and AFR? Is a head designed for a 4" bore like the AFR 215 my best bet? I really don't want to spend that much on heads, but if it really is truly worth it I can be patient to see what pops up used.
Where would untouched 243's get me?
Keep in mind these will find their way onto a LQ9 in a 5800 lb daily driven crew cab pick up truck. My race weight will be 5300-5400 this spring. My end goal after heads and the converter are installed is to run 12's in a crew cab 4x4.
1 7/8" catless ARH
A little bit of conflicting advice here... 225's or small port design? I don't know why but I like the idea of a head that takes advantage of the larger 4" bore of the 6.0.
Shifting at 6400 or so will I even see the benefit of 225 over a 215 or 205 head? I guess my question is where do the larger ports really start to shine, and how well do they compare at 3k RPM or even lower? Are there any direct dyno numbers to show this? I tried to search and came up with nothing, I'd also be interested in any dyno comparisons available for the 205 vs 215?
Thanks for the opinions guys. Keep em coming!
The ultimate choice would be to find some used AFR 205's and send them to Tony to get lightly ported or "Mamofied". They've proven to work very well even on a 402. The new 210's untouched would be about the same but with either choice, you'll be looking at spending close to $3k once you factor in the need for roller rockers and possible upgrades such as valve springs.
If that's not in your budget, the best OEM option would be AI ported 243/799's. Several have eclipsed 500rwhp with these on 6.0's with excellent under-the-curve power, and I doubt you'd be disappointed with the low end.
Jason
Jason
3k is definitely more than I would be willing to spend. I think I could get a really complete TVS1900 for about 4k, and no set of heads will give me the power that one of those would.
At this point I'm leaning toward the AI's since they seem to offer a great bang for the buck.
Yea I have been seeing real impressive power numbers with them too. Crazy stuff. I sent them an email to see how they would respond and what they would recomend for me. I wonder if the smaller port job would be a better option since I don't really rev all that high.
Who knows... I have emailed some other people who I think would be good options too.
I'm afraid comparing 6.0 head choices in 3500lb cars with a stall converter to your heavy truck will leave you wanting more down low. The AFR heads will give you the most velocity and low end throttle response because nothing else flows close to what they do at 205 to 210 cc's. You don't need 215's either for this application, 205's and 210's work great on a 4" bore, and you stand to lose more power where it really counts by going bigger than you need.
You don't have to get AFR heads 'Mamofied' for your application, and you should not have to anything other than stock rockers either.
If you can't save up for them and insist on a ported stock casting, get some 243's and send them to AI for the performance rebuild. You get a good vavle job, without enlarging the port anymore than necessary -inexpensive, and will make significant gains without going to big.
I totally agree, and that's why I suggested looking into AFR 205's. You can find them used in the classified section for around $1,500.00. The 205's will give you great power under the curve and still flow well enough for power up top.
With 38 less cubic inches, you are not in danger of running out of air flow on your 6.0. Any gains from the bigger head would only come in the upper rpm ranges which you rarey see on a street driven truck.
