Anyone with HEMI heads on their LS?
Anyone out there with HEMI heads on there LS powerplant? I'm curious to see if they are even worth swapping. I know it's probably impractical/expensive to switch to HEMI heads, as you'd have to pickup a ton of parts that were previously only compatible with wedge heads... but, cost aside, are they worth it???
Also... I'm not sure how HEMI heads would fit on an LS1 in an F Body, it's pretty tight in the engine bay to begin with?
-Marcus
-Marcus
Yea that's what I mentioned... There are so many people out there making serious power with just some CNC'd 241s or 243s, an LS6 intake and a good size cam. But I'm somewhat interested in HEMI heads because thinking about it, average HEMI designed heads should drop the compression wouldn't it (probably lower than 317 heads)? And I want to pickup a turbo sooner or later and having HEMI heads and some low compression pistons... you could run a LOT of boost on pump gas (assuming you have better internals) since the compression would be so low. Again, it does go back to the cost/effort, which is why I wanted to see if anyone would vouch for their performance.
man that looks ridiculous...
That double staged rocker setup is just asking for trouble. Actual hemi heads don't have that. They have shaft mounted rockers with offset lifter bores. Plus a real hemi head has 2 spark plugs per cylinder.
Here is a link to show what they are capable of!!
http://board.moparts.org/ubbthreads/...c=&Search=true
But its still cool just cause its so crazy!
Yea **** on hemi heads...a new modern fuel injected 426 crate motor only makes 590 hp...that's with a pretty hot cam...if you put a hot cam in an ls7 you are looking at 600+ hp easy...
It's funny you brought it up but I have seen LS series hemi heads...it would be trick but prob have to have a sheetmetal intake I imagine...
Moderator
Although I own an F Body I actually love Mopar's... NOT new Mopar, that's just a goddamn disgrace to domestics. Old Mopar has always been my interest. And as for a HEMI, it's just a head design, so why not put them on an LS? I'm crazy about forced induction, so HEMI heads would really help with opening up the boost potential on an LS. I could go with some 317s on an LS1 and call it a day, but imagine how much boost you could run with the bigger combustion chambers of HEMI designed heads?
i love the look of the hemi heads and all
.........when i read this this morning..............
but i am still going to check these out as i may be one of the few that may make the purchase of the kit, being that i have the funding and all..........and see what this combo is really going to due
will start a new thread when i get my new parts
