car seems to have no power at all
Old 01-22-2012, 06:34 PM
fastazzls1's Avatar
Default car seems to have no power at all
i have a 2000 trans am ws6 car seems to have no power down low its m6 with 3.42 rear axle ratio with 30k miles it just doesnt seem to pull very hard throught the rpm range, my brothers car pulls very hard and its all stock as well was wondering what could be the possible problem if any no misfires check engine light or anything in that nature
Old 01-22-2012, 06:37 PM
nomasterase's Avatar
Dirty maf sensor or plugged fuel filter maybe?
Old 01-22-2012, 06:38 PM
Intimidator02SS's Avatar
Try unplugging the mass air flow sensor and driving. This will flag a check engine light FYI. Other than that, you should really have it checked out. Do you know anyone with a diagnostic scan tool?
Old 01-22-2012, 07:15 PM
crainholio's Avatar
Might get better replies if you post in the right forum.
Old 01-22-2012, 07:27 PM
RedHotG8's Avatar
Clogged cat converters with cause a loss of power.
Old 01-22-2012, 07:51 PM
ilovechevy1's Avatar
ummm, make sure nobody stole your LS1 and swapped it for a 4.6L stang engine. If they did then there's your problem lol..I'm jk of course
Old 01-22-2012, 07:58 PM
fastazzls1's Avatar
thanks i do notice a bit of a stumble at idle and the car has been neglected on the service aspect of its life my neighbor has more money than brains for this is who i bought it from
and sorry for posting in the wrong section lol
also took it this evening ran it pretty hard had a rotten sulphric smell coming from the car only after i ran it hard
Old 01-22-2012, 07:59 PM
mannyman84's Avatar
How long have u had your car? Is your bros an a4?
Old 01-22-2012, 08:16 PM
fastazzls1's Avatar
4 months i had an ls1 in a s10 blazer and it pulled like a ******* freight train
and yea my bros car is a 2002 z28 a4 i know the axle ratio is 3.23 car is all stock too 60k on his pulls and pulls and pulls mine just peters out and doesnt really get out of the whole very hard
Old 01-22-2012, 08:19 PM
RedHotG8's Avatar
That smell is from the cat converters, like I said earlier they are clogged.
Old 01-22-2012, 08:25 PM
fastazzls1's Avatar
thanks red hot g8 what could cause the catalytic conveters to basically prematurely wear out poor fuel and what would be your suggestions for resolving my issue
Old 01-22-2012, 08:30 PM
smokin91rs's Avatar
if the cats are clogged or you think they are, you can pull the o2 sensors pre cat or loosing the y-pipe to create a exhuast leak before the cats take it for a quick test drive, if it pulls harder(becuase the car can breath now) then the cats are clogged.
Old 01-22-2012, 08:38 PM
fastazzls1's Avatar
i will try this give me a few minutesand will post results i hope this works if it does i am going to run kooks and ory
Old 01-22-2012, 08:52 PM
fastazzls1's Avatar
just made a pull down the road not a big change but it was noticeable when nailing it down low
Old 01-22-2012, 08:56 PM
82cetuner's Avatar
gut your cats or replace them you found the problem
Old 01-22-2012, 08:59 PM
fastazzls1's Avatar
yes sir time for some mods long tubes will be the first thing and exhaust any sugesstions on ory and muflers
Old 01-22-2012, 09:18 PM
mannyman84's Avatar
Check fuel pressure aswell
Old 01-22-2012, 09:20 PM
mannyman84's Avatar
Did you just feel this or has it been happening? A4's tend to pull little harder down low when power braking and running it. But m6 will pull better up top. What RPM are you launching at?
Old 01-22-2012, 09:25 PM
sepsis's Avatar
Well, you're still restricted by the cats and the small *** O2 holes provide just a little relief. You noticed the difference though, so like 82cetuner said, you found the problem.
We had the same problem with my old mans Dodge Ram. We gutted the cats and it was perfect. Good luck bro, let us know how it turns out.
