valve spring kit...
I would recommend our PRC .650 dual spring kit, which will be able to handle that camshaft with ease.
Here is a link to the kit on our website.
http://www.texas-speed.com/p-474-pre...pring-kit.aspx
This spring kit can be used with just about any rocker arm setup you decide to go with. This kit also installs with no modifications to your stock cylinder heads. Your stock locks will be fine, but if you lose some or feel like replacing the factory ones its a rather inexpensive purchase.
Right, the Lunati kit comes with tool steel retainers. They are extremely strong and fairly lightweight. Do you have actual weights for the two in question or are you just rattling off useless info? You are aware that titanium, while light, is an extremely soft metal. Some would choose a stronger valvetrain at the expense of a tiny increase in weight.
well maybe i should have added "in my opinion" to it, but yes theres a few companies making tool steel retainers that are a few grams heavier than there titanium retainers.
I should have added that i also have the ZO6 valves which are lighter than regular valves, so titanium retainers will be the lightweight theme Im going with..
Tool steel retainers will last longer, they are more Daily Driver friendly, The titaniums usually get replaced once a year if your like me and do alot of spirited driving like i do..
I'd like to see weight comparos between the most popular brands of retainers, and hear some of the engine builder's opinions on the effect on upper rpm engine operation and valvetrain stability.
