LS6 top end on LS1, pushrod length?
Old 02-07-2012, 09:29 AM
boostnut's Avatar
Default LS6 top end on LS1, pushrod length?
I have an opportunity to pick up a set of complete 243's, the cam and pushrods from a 2002 Z06 for a pretty sweet price. Obviously the heads & cam would be a nice upgrade for my stock LS1 w/853's but will I need to purchase different pushrods? I understand the base circle of the cam is smaller but I'm assuming (you know what happens here) the LS6 pushrod length will compensate. I'm also assuming these heads have the sodium filled valves since they're 02's.
Please correct me if I'm wrong.
Old 02-07-2012, 12:52 PM
kenp's Avatar
Ls6 & Ls1 pushrods are the same length.
Old 02-07-2012, 12:58 PM
ZeeOSix's Avatar
I'd think if all the parts from the cam to the heads are off the LS6, it should all bolt on with no issues as long as the head gaskets are the same too. Still would recommend checking the pushrod length to be sure.
Old 02-07-2012, 02:12 PM
boostnut's Avatar
Hmmm, guess that means the cam placement is different in the blocks?? Also means I'll have to spend some extra $$$$ on pushrods. Is there any way around this?
Old 02-07-2012, 02:15 PM
thompson's Avatar
They are the same, No difference in pushrod or dimensions outer or inner (for all intensive purposes) you can use your stock GM pushrods. The base circle will only be different if you have had the cam reground in which case I would not be installing it anyways.
Old 02-07-2012, 02:26 PM
blue98Z's Avatar
Dude, they're basically the same motor. Just the ZO6 has a better top end and cam. EVERYTHING swaps over. Don't over think this, and no the cam placement isn't different. It's right down the middle just like in an Ls1, 2,3,6,7,and 9
Old 02-07-2012, 02:44 PM
redbird555's Avatar
basically what everyone has already said lol. if you get the heads and cam the pushrods will be the same. the ls6 cam has a smaller base circle however the ls6 valves are .025 taller than the standard ls1 valves so basically if you get ls6 heads and valves then you are good with the stock pr's. if you get an ls6 came with standard 243's and regular valves you will need 7.425 pushrods
Old 02-11-2012, 10:31 PM
yaknow's Avatar
Your golden, drop em in and go
Old 08-08-2012, 04:25 PM
JoshuaGrooms83's Avatar
sweet, always nice to find usful information
Old 08-08-2012, 04:48 PM
ls1jorge's Avatar
ls6 topend & cam on ls1 your gonna love it! especially if your an a4 with 4k stall its gonna be a nice setup.
Old 08-08-2012, 05:15 PM
andy-lswon's Avatar
Be a nice set up if I could get lucky enough to run across it for cheap lol
Old 08-09-2012, 09:59 AM
ls1jorge's Avatar
I picked up both my 243s, ls6 cam, ls2 chain for little under 350.
Old 08-09-2012, 10:36 AM
white99ta!!'s Avatar
Thats the best deal i heard of in a long long time.
Old 08-10-2012, 04:46 PM
FASTFATBOY's Avatar
A LONG time.
I bought my topend off a 2003 Z06, heads,cam,intake, pushrods for $1000 shipped and thought it was a good deal about a year ago.
Old 11-23-2012, 06:43 PM
donsvulcan's Avatar
What about the head bolds, are they the same length? And should new ones be used?
Old 11-25-2012, 12:08 PM
BLKLS1240SX's Avatar
what part of everything swaps over do u not get lol
Old 11-25-2012, 12:54 PM
A.R. Shale Targa's Avatar
Head bolts are torque to yield (one time use) and should be replaced......
Stock replacement bolts and GM MLS head gaskets can be had from Texas
Speed for a little over a hundred bucks.
Old 02-02-2013, 02:40 AM
ingeniusone7's Avatar
im doing a ls6 top end on my ls1 vette as well I only have the 243 heads right not. But they did not come with pushrods...just so im sure i can use the stock ls1 pushrods that are in car currently with the 243 heads?
Old 02-02-2013, 03:03 AM
PREDATOR-Z's Avatar
When in doubt (actually anytime) MEASURE
Old 02-02-2013, 08:23 AM
FASTFATBOY's Avatar
I did, and I had my block decked to cleanup and my heads milled.
Runs great, slight amount of valvetrain noise but the car is quick.
Quick Reply: LS6 top end on LS1, pushrod length?
