Stock piston removal cracking.....
Old 02-16-2012, 06:30 PM
mcfarlnd's Avatar
Default Stock piston removal cracking.....
Anyone with experience have this issue while removing the pistons from the rod?
Sent my stuff to the machine shop and they cracked two of my pistons while removing them from the rods. They tried saying it happens all the time while dealing with stock stuff...... I say BS. I've had this done multiple times and haven't had an issue until I use a different machine shop due to relocation. Any thoughts? And they said I need to pay for the new piston....
Name of the shop is QMP performance, chatsworth California.
Old 02-16-2012, 06:38 PM
3rdCoastPowerSports's Avatar
the only way i now to crack a piston during removal is to drop it on the ground when your pushing it out of the block. The engine is on the engine stand turned upside down, they undo the rod bolts/caps and push the piston out onto the concrete floor. I have removed several sets of stock pistons from LS blocks, never dropped or cracked one
Old 02-16-2012, 07:09 PM
Marc 85Z28's Avatar
It's common with poor technique or lack of proper tools.
Old 02-16-2012, 07:31 PM
remauto1187's Avatar
Ouch. Im guessing you have pressed in wrist pins and the cracked them then?
Hey, if You need some std pistons out of an LM7...ive got one block disassembled right now. It has 100k on it.
Old 02-16-2012, 07:43 PM
mcfarlnd's Avatar
Removing pistons from the rod lol! Not from the block.
Old 02-16-2012, 07:47 PM
haha ok still i have never cracked a piston removing it from the rod.
Old 02-16-2012, 07:50 PM
mcfarlnd's Avatar
Correct, pressed wrist pins. LM7 are dished correct? I was trying to get them to remove the dished pistons and install the flat tops from the 4.8 on the 5.3 rods. Then re-balance everything. It was going to be a cheap upgrade while I'm rebuilding the motor.
Old 02-16-2012, 08:23 PM
yeah these are dished.
Old 02-17-2012, 02:01 AM
mcfarlnd's Avatar
Could you please enlighten me on the proper technique? Or anyone know the "correct" process? From what I have seen done from my previous machine shop, they used a small oven with a fixture and used different combinations of press dies depending on application. I asked QMP if they used heat, and they said, "they only use heat for install." I would think heat would make the two malleable and less prone to cracking.
Old 02-17-2012, 02:06 AM
bww3588's Avatar
It takes a special adapter to remote ls pistons from rods. Most machine shops try to use the standard sbc adapter and that is what cracks them. I took a set of mahle pistons to a machine shop that I sold, he busted the first one and I asked him if he was using the ls adapter and he said they were the Same. I packed the remaining 7 up and went to a different shop that had the adapter and didn't have any trouble with the rest.
That being said, I ate the cost of a replacement piston.
Old 02-17-2012, 02:10 AM
bww3588's Avatar
For what it's worth, I also had a shop crack 3 of my stock pistons using the wrong adapter. Tried to tell me it happens all the time...
Old 02-17-2012, 02:17 AM
mcfarlnd's Avatar
Interesting, to know there is an actual adapter. The piston is only costing me $40 for a set of 8. 4.8 pistons are plenty and no one wants them lol! All BS aside, even if it cost me nothing, it's the fact that the guys just assume it is standard practice to crack a piston..... Then tell the customer well, it happens everytime when working with stock used stuff....... They sure as hell didnt make it a point to tell me this before I dropped my stuff off!
Old 02-17-2012, 02:34 AM
bww3588's Avatar
They tell you that after they bust a couple because most people don't know any better and just assume that's the case and let it go.
The people at the machine shop know its not common and know they fucked up, they just don't want it coming back on them.
I can see it happening sometimes on a piston/rod assembly that is 50 years old and sitting in the woods for 20 years, but not an ls engine that was most likely running recently.
The adapter must sit flush on the wrist pin boss and not on the ring lands or skirt area. The sbc adapter will sit on the bottom ring land just a little and end up busting the piston just above the pin boss and usually all the way across the top of The piston to the other pin boss.
Is this where yours cracked?
Old 02-17-2012, 02:38 AM
mcfarlnd's Avatar
You have me really curious about this. Do you have a part number or manufacturer of "said" adapter? I would like to atleast look at a photo so, I can compare it to what they use.
Old 02-17-2012, 02:41 AM
mcfarlnd's Avatar
Haven't picked my stuff up yet. Headed to pick it up in the A.M. I'll post up pics when I get them back.
Old 02-17-2012, 02:45 AM
bww3588's Avatar
Right now I do not, I am at work. I have to make a trip to the machine shop here after work I will try to snap a pic of hip adapter.
Old 02-17-2012, 06:02 AM
RezinTexas's Avatar
Here's how I did it.
[IMG][/IMG]
Old 02-17-2012, 07:06 AM
bww3588's Avatar
talk about home grown ingenuity. good call. whats wired to the base of the press?
Old 02-17-2012, 09:37 AM
RezinTexas's Avatar
its just a wire to hold down the big iron plates from sliding off.
Old 02-17-2012, 09:58 AM
K11PER's Avatar
I need to sell my pistons and get them off the rods still. Guess I'll attempt it myself and try your method above, give me good practice for someone whos never done it before.
Quick Reply: Stock piston removal cracking.....
