2 quarts in 1,000 miles?! Now what?
Low oil light came on this morning after about 1,000 miles since the oil change. Checked it when I got to work and it was 2 quarts low! I was in shock to say the least. I typically lose about 1 quart every oil change which is 3,000 miles. My question is now want? What do I need to check and is the bottom end shot? Car has it sits has 126,000 miles on it with 26,000 of those being heads/cam and your typical bolt-ons. Any advice would be great, but my plans as of now are find a 6.0 and do a 408. Only thing with that is my Patriot stage II 5.3's on the top end will be useless. Thanks in advance fellas!
No smoke and no noises that I have noticed. Motor is always loud anyway with the cam so it would be hard to tell if it was something small. I plan to pull all the plugs just to check those and see if they are covered in oil or anything.
Very first time it's ever been this low shy of when I'm changing it lol. Happened within last oil change yes. No smoke seen and no noises present that are out of the norm. I have not checked the coolant yet
