5.3, 5.7, 6.0 - what did they come in?diffrences?
Old 03-23-2004, 09:25 PM
chief455's Avatar
Question 5.3, 5.7, 6.0 - what did they come in?diffrences?
My 00 Formula LS1 is a 5.7, right?
I see many sigs with 347 - is that what mine is - not a 350?
What did 5.3 LS1 and 6.0 LS1 motors come in and what major differences are there?
thank you -
Old 03-23-2004, 09:43 PM
1BADFNZ's Avatar
The 5.7 ls1 is actually 346 cubic inches. The 5.3 and 6.0 are derivatives of the LS1 and are used in the truck line primarily.
The 5.7 LS1 is the one used in f bodies and vettes. It's the high ouput high performance all aluminum while the 5.3 and 6.0 are used in trucks and I think they use a steel block with aluminum heads.
Old 03-23-2004, 10:15 PM
DenzSS's Avatar
Iron block, not steel.
Old 03-23-2004, 11:57 PM
1BADFNZ's Avatar
Same difference j/k
Old 03-24-2004, 04:04 PM
FILE's Avatar
Just curuious why is that ls1's are rated at 305 hp and get dyno #'s of 290+ while 5.3(lm7) are rated at 285 hp and put out dyno # of 235-245?
Old 03-24-2004, 04:06 PM
DenzSS's Avatar
5.3L and 6.0L often have much higher drivetrain losses.
Old 03-24-2004, 05:53 PM
rushman's Avatar
The rumor is that f-body ls1's are under rated from the factory to keep potential corvette buyers from "settling" for an f-body
Old 03-25-2004, 03:14 PM
1BADFNZ's Avatar
Well if you look at the 5.3 you see a normal if not good 15% drivetrain loss. This is what you'd expect, actually a little better but still normal. Now if you look at the 5.7 liters loss using the factory numbers it'd be only 3% !!!! Of course we know that's impossible, it has to have the same parasitic drivetrain loss as everyone else about 15% or so. That would give it a crank HP rating of about 347 - 350 hp, in other words the same as the Vette Gm just severly underrated it to preserve the ego of the vette. So I think it's safe to say that it isn't a rumor
Old 03-25-2004, 05:17 PM
ktmrider's Avatar
I agree with 316, in addition it helps keep the insurance premiums to an ungodly level, not an unobtainable level. I knew a 30+ female schoolteacher with an impeccable driving record that would have been hit up for around $200 per MONTH if she had gotten the V-8 in her f-body! This "underrating" goes back to the old muscle car era and the adoption of the numerical systems. W-37 code in a Firebird slipped under the insurance radar and let the public own a real street car back then without the underwriters laughing them out of the office.
