Replace timing set or just chain?
Old 03-21-2012, 07:28 PM
batboy's Avatar
Default Replace timing set or just chain?
Just got a 5.3 Tahoe and thinking of installing a small cam (along with pushrods, valve springs, and new seals). At 97k miles, for peace of mind I'll probably swap in a new oil pump at the same time. Should I get a complete timing set or can I get away with just a new chain? Obviously, I need to inspect the gears, but generally the gears hold up way better than the chain, right?
Old 03-21-2012, 07:49 PM
silver6speed's Avatar
At 97,000 miles, no need to change pump. Its a gearator pump. They just don't fail!, unless u have a blow up and metal goes through it. Just swap the chain only. You'll be good!!!
Old 03-21-2012, 07:57 PM
batboy's Avatar
I never heard of a gearator pump. After a brief search, I see you probably mean gerotor pump. I've seen tons of these 5.3 engines run well over 200k miles, so they must be tough.
Old 03-21-2012, 08:46 PM
Darkman's Avatar
Based on motorcycling experience I can never bring myself to install new chain on used sprockets. Besides timing sprockets are not expensive.
Old 03-21-2012, 09:52 PM
ThumpnZ28's Avatar
Just go with the LS2 chain and you should be good. Its beefier. Like $40 from most GM dealerships.
Old 03-21-2012, 10:10 PM
01ssreda4's Avatar
I like to replace the timing as a set. Yank sells the set for around $70 shipped.
Old 03-22-2012, 07:29 AM
redtan's Avatar
Plenty of oil pumps have failed, and upgrading it while in there already is always a good idea.
Old 03-22-2012, 09:58 AM
redbird555's Avatar
agreed plenty of oil pumps fail and foor about 100 bucks its def worth the peace of mind. just get a ported ls6 or melling pump and call it it a day
Old 03-22-2012, 10:09 AM
91sonomast's Avatar
Yeah, an oil pump is in the neighborhood of $150-200 depending on which route you go, cheap insurance, and I'd replace the timing set as well. Guess I'm like Darkman but I always replace the sprockets. Seems with motorcycles and ATV's if you replace just the chain, the sprockets wear quicker and it also wears your chain quicker.
Old 03-22-2012, 11:13 AM
pairof69s's Avatar
what would be another option to the LS2 chain, I don't like the slack i've seen with those.
Old 03-22-2012, 11:19 AM
batboy's Avatar
When I did the cam in my LS1 GTO, I just replaced the timing chain with a heavier duty LS2 chain, but I had less than 20k mile. With nearly 100k on this 5.3, I'm beginning to lean towards replacing the oil pump and complete timing set. I really don't want to open it back up anytime soon.
Old 03-22-2012, 01:38 PM
Darkman's Avatar
I like the Katech/IWIS chain sold by Thunder Racing (among others).
http://www.thunderracing.com/shop-by...Chain_349.html
Old 03-22-2012, 07:40 PM
batboy's Avatar
The IWIS chain is a lot cheaper at Scoggin Dickey.
Scoggin Dickey also has GM oil pumps with o-ring for $73 and N-Motion roller timing sets for $67.
Old 03-23-2012, 06:17 AM
Darkman's Avatar
The IWIS chain at Scoggin Dickey is not the Katech version and is not as good as the LS2 chain.
https://ls1tech.com/forums/13825166-post2.html
Old 03-23-2012, 11:17 AM
pairof69s's Avatar
what about rollmaster....?
Old 03-23-2012, 02:40 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Please don't spread poorly informed hearsay as fact. It is NOT a weak chain, and is not a bottom of the barrel chain in any way shape or form. Stating that it is not as good as the LS2 chain is simply untrue and uninformed. It is a genuine IWIS chain and has been proven in thousands of builds.
It is obviously not the same IWIS chain as the C5-R chain (which we also offer) and has never been advertised as such. It is simply a reliable and affordable option for those who are not in need of a $130 timing chain. Different chains for different needs.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 03-23-2012, 03:56 PM
Darkman's Avatar
I apologize if I misinformed anyone by representing opinion as fact.
On the other hand, I never said the chain was not genuine IWIS, nor did I say it was weak. I did want to make it clear that the two chains being compared were not the same.
Old 03-25-2012, 02:11 PM
PREDATOR-Z's Avatar
It all depends if you want to "replace" or "upgrade"
If you cam it, I would get an adjustable chain to be able to degree the cam (advance/retard)
Quick Reply: Replace timing set or just chain?
