Clay and PTV?
Ph.D. in HUBRIS
Clay and PTV?
I know there a many threads but since it is so important I am hoping to directly answer my questions.
I was hoping to use clay but seems like using the hydraulic lifter will throw the numbers off significantly. Is there a way to overcome the hydraulic lifter, such as a max value that it will compress? I have been busy and somewhat avoiding checking this for the reason of making sure it is all correct. I am finally trying to tackle it and need some advice. Thanks.
I get this overcame and she should be running in a week or less!
Tack welding an old hydraulic is a very good idea. I have found tootsie rolls work better than modeling clay - the wax paper they come in does not stick to the piston. Peel off and measure.
You would follow the dial indicator method but use a feeler gauge to measure the movement of the valve from zero lash. In other words, you would start before TDC of the exhaust stroke with check springs at about 20 degrees before the piston reaches the top. Move the crank in 2 degree increments and then use feeler gauges to measure between the rocker tip and the valve stem when you push the valve down so it is in contact with the piston. If the gap is huge, then move to the next step. Doing this carefully (not lifting hard on the rocker tip) should prevent pushing the lifter plunger down and getting a false reading.
