Largest crank for a 5.3
The largest stroker kit I've seen for the 5.3 is a 4.0" stroke which makes it 363 CID (5.9L). You can bore the 5.3 block out to 5.7 bore size and then use a LS1 stroker kit for 383 CID (6.2L).
I just installed a 4" crank in my LM7 and the rod bolts have maybe .060-.070" clearance to the cylinder wall edges. A 4.125" crank will likely require some clearancing, but its probably not a big deal.
