Callies Compstar H Beams good for 800rwhp?
Old 03-31-2012, 02:13 AM
ajrothm's Avatar
Default Callies Compstar H Beams good for 800rwhp?
I can not seem to find an accurate HP rating on these rods.... Nothing about HP on callies website... Texas Speed claims they're good for 900 crank HP but...I can not validate that anywhere else...
Anyone KNOW for sure if the Compstar H beams w/arp 2000 bolts are good for 800 rwhp (boosted M6 car) ?
Thanks in advance...
Old 03-31-2012, 09:09 AM
JS01's Avatar
Will be overkill for 800rwhp, have seen them run to 1300rwhp and beyond.
Old 03-31-2012, 01:52 PM
ajrothm's Avatar
The regular $600 H beams w/arp 2000 bolts?
Damn...
I read on another board that callies unofficially rates them at 750 crank hp...
I am hoping they are stronger then that for sure....My builder recommended them but I don't want to be on the border line with this....
Surely there are more people here running the compstar h beams that have dynoed tested them?
Old 03-31-2012, 03:21 PM
ls68firebird's Avatar
r.p.m's and detonation are bigger rod killers than horsepower.
Old 03-31-2012, 04:37 PM
1lejohn's Avatar
Thats for sure. I 've run the same set in 2 builds. They are a tough piece. Mid 700 on spray here.
Old 03-31-2012, 06:41 PM
BigRich954RR's Avatar
they been run in 1k hp builds all the time one guy folded a pair but it wasnt till 1950 hp they had a few runs dynos in the 1600hp zone ithink
Old 03-31-2012, 06:42 PM
mebuildit's Avatar
Why not call Callies vs. Taking someone's word. probably get the answer you are looking for.
Old 03-31-2012, 09:09 PM
703 CAMAROSS's Avatar
If it makes you feel any better I'm using them for my 1k whp build. Who knows when il actually make those #'s though it costs so damn much
Old 04-03-2012, 03:05 AM
ajrothm's Avatar
A rep from Callie's rates them at 750 crank HP....
Needless to say, I didn't believe that...
So I am getting info from those that have actually made big power with them... Not what they "should" be good for... I don't want to spend $1200 on rods if the $600 will do what I want safely.
Old 04-03-2012, 05:13 AM
if you have the money get the best rods you can dyers or what ever and you will have them for life almost.
i had a part fail on me with every thing my engine spiked at 12k rpms for i think .43 of a sec on the log the 300m rods held with heavy tool steel pins and boost pistons I floated the **** out of the vavles. im pretty sure cheaper rods would have failed
Old 04-03-2012, 05:45 AM
No Hope's Avatar
Buy the Callies ultra billet I beam or H beam. The I beams are rated to 1200rwhp. I can't find the rwhp rating for the H beam but it should be close to that.
Livernois has a crank, rod, piston and accessories package for the Callies ultra I beam.
Old 05-22-2012, 07:45 PM
I8UR4RD's Avatar
bringin it back
Old 08-25-2013, 06:57 PM
Blown02Camaro's Avatar
[QUOTE=ajrothm;16143791]I can not seem to find an accurate HP rating on these rods.... Nothing about HP on callies website... Texas Speed claims they're good for 900 crank HP but...I can not validate that anywhere else...
Thanks in advance...[/QUOTED
Due to the clutch in the car im making 721rwhp on the compstar H beam. Could go higher if I had a stronger clutch
Quick Reply: Callies Compstar H Beams good for 800rwhp?
