What head gasket for 408?
Was wondering if I can run this headgasket on my 408 LS3 headed build? 4.060 bore. http://www.summitracing.com/parts/TFS-30694060-045/
i asked texas speed if i could run the 4.060" gasket and Aaron there said it would be okay. I'm just confused now since he said it would be fine and the other person told me it needs to be 4.080". I need more input on this!
Because the chamber size is a tad bit bigger or right on the edge of 4.060 as it is. The fire ring may not seat well. As Jesse at Scoggin Dickey, they sell them all the time.
Would this gasket work? http://www.summitracing.com/parts/FEL-1041/ and is .034" quench running it to close on a street 408? i measured my pistons and they range from .005-.007 out of the hole.
Why are you so against the cometics? You should use a 4.085 gasket in any thickness you want. Thats it. As long as you abide by that you are ok. No need to complicate it with a 4.100 or larger gasket, you have the answer in front of you. SD can get you the gasket you need.
I'm just under a budget and wanted to order everything from the same site to same all the hidden shipping costs. I'll prolby just end up ordering the Cosmetic LS1 4.085" gaskets from texas speed.
