comp. trunion upgrade problem
Old 04-07-2012, 04:45 PM
Turd Gen Guy
1nasty86's Avatar
Default comp. trunion upgrade problem
well as most of you know my ls2 went kaput.. i was moving the heads around today and i grabbed the one that had not been damaged by the piston and i heard something come out of it.. turns out to be this
thought to myself ...where have i seen that before.. then it hit me i looked and sure enough i found this
GREAT so how did i install the rocker bearings wrong? i followed the instructions and its not just one rocker, its a few of them
Old 04-07-2012, 05:42 PM
raven154's Avatar
You probably just stretched the snap rings too far when you reinstalled them.
Old 04-07-2012, 05:51 PM
Turd Gen Guy
1nasty86's Avatar
i havent touched the rockers in over a year and i installed the trickflow heads 2 months ago.... just found the snap ring tip in the trickflow head today
Old 04-07-2012, 05:58 PM
SSdreamz's Avatar
id just buy all new snap rings and call it a day
Old 04-07-2012, 06:17 PM
Turd Gen Guy
1nasty86's Avatar
just bothers me that this happened.......
Old 04-07-2012, 08:11 PM
rickyzZ28's Avatar
How much side play do you have on the rockers? Is the center of the rocker hitting the snap ring by chance? Could be the problem, but if they are fine I would just put new snap rings on and run them.
Old 04-07-2012, 10:40 PM
Hy82e's Avatar
hmm.. subscribed
Old 04-07-2012, 11:44 PM
ZeeOSix's Avatar
Strange failure. I'm thinking there must have been a stress riser/defect in that snap ring. The snap ring sits in the trunnion groove and there really isn't any load on it besides it's own spring tension. Look in the groove on the trunnion and see if maybe there's a flaw/protrusion in the groove that might have caused stress on the snap ring.
Old 04-08-2012, 12:05 AM
Turd Gen Guy
1nasty86's Avatar
It is more than one rocker tho... Some are broke on both sides! Just glad I found it now instead of when I was having to pull my head again to replace a spring or even have to rwbuild the motor... This is truly strange
Old 04-08-2012, 02:42 AM
ausls1's Avatar
Interesting, any one else had this problem? Or any other problems with them? I'm just about to do mine, iv got a new set off the upgraded gm ls1 rockers that im about to dismantle and put the trunion kit through.
How much lift are you running on your cam?
ZeeOSix's Avatar
I'd be contacting Comp Cams to see if anyone else has reported this failure. It's possible they had a bad batch of snap rings that had some kind of defect or maybe weren't heat treated properly.
How long has that Trunnion Kit been installed?
Old 04-08-2012, 02:43 AM
ausls1's Avatar
Trickflow heads aren't the ones you have to run roller tip rockers on are they?
Old 04-08-2012, 06:56 AM
That's MISTER MODERATOR
Paul Bell's Avatar
I'd say this is wrong. Obviously there's a problem and simply replacing them may not fix the cause of the problem. Replace them and cross your fingers it doesn't happen again?
THIS^
And like raven154 said, you may have spread the rings too far during installation.
Old 04-08-2012, 07:35 AM
SweetS10V8's Avatar
This is my first thought. Ive installed tons of these without issue.
Old 04-08-2012, 10:00 AM
Turd Gen Guy
1nasty86's Avatar
The rockers have been upgraded for over a year and my cam specs were 230/238 .600/.604 112+2... I hope it was just the snap rings being over stretched because my new cam is beastly compared to my old
Old 04-08-2012, 12:18 PM
Bramlok's Avatar
I don't know about that stretching them too far comment. They are meant to be expanded for installation just like any snap ring. But it is possible they were a defective bunch as most snap rings are very tough and hard to break like those did.
Old 04-08-2012, 03:40 PM
RonSSNova's Avatar
I agree. Just try and break one on purpose. Very difficult.
Ron
Old 04-09-2012, 11:05 AM
Turd Gen Guy
1nasty86's Avatar
well snap rings a piece are 5 cents so i dont thing im out much... but still bothers me that some of them broke
Old 04-09-2012, 04:25 PM
Paul Bell's Avatar
Have you contacted Comp?
Old 04-09-2012, 05:48 PM
Turd Gen Guy
1nasty86's Avatar
that is where i got the price quote.. he told me this was the first case he knew if a snap ring failing
Quick Reply: comp. trunion upgrade problem
