My oil pump bad?
Old 04-25-2012, 07:00 PM
sfc rick's Avatar
Default My oil pump bad?
I don't think my oil pump has much more life left. It's running 23lbs at hot idle and a little ticking comes off the valve train. When it's cold it's at 38lbs at idle and almost 50lbs at 3500rpm, and no ticking. After it's hot it's at 28-29lbs at 1500rpm. The engine has 100,000 miles on the clock and runs really strong. a year ago I installed a new 228R cam and lifters, BUT NO OIL PUMP or Timing chain. I tried to keep the costs down. I also had a valve job done on the heads in January. I pulled the valve cover and checked the rockers for trunnion bearing damage and any pushrod slop.
I'm going to call TSP and order a new higher flow Melling oil pump and a new LS7 Timing chain next Monday.
Does that sound like a plan? I'm thinking last year my stock oil pump was like 45-50lbs at idle?
http://youtu.be/AbokjJ6O8AQ
Old 04-25-2012, 07:47 PM
Darkman's Avatar
I would change the timing sprockets with the new chain - they are not very expensive.
Old 04-25-2012, 09:17 PM
3rdCoastPowerSports's Avatar
im sure you've done this but have you verified your oil pressure with a mechanical gauge?
Old 04-25-2012, 09:23 PM
SWEET98SS's Avatar
Im dont think oil pumps wear out but I could be wrong. When I had oil pressure problems, it was my bearings.
Old 04-26-2012, 12:15 AM
cranny's Avatar
I agree with SWEET98SS. A gradual drop over time sound like rod or main bearings wearing out. Possibly even cam bearings.
Like it was mentioned, you may want to plug a mechanical gauge on it to make sure.
You could also change the oil with a heavier weight to test it. If a 20w-50 raises the pressure, it may indicate worn bearings.
Old 04-26-2012, 01:57 PM
sfc rick's Avatar
Just pulled the driver side rocker arm assembly and reassembled it and no ticking.....oil pressure is fine by several sources who most all agreed the oil pump isn't the issue. Unfortunately I don't have a clue what happened to fix the ticking issue and hate it when I don't know the for a fact what it was?
http://youtu.be/CSxFfVkJpdg
Old 04-26-2012, 02:36 PM
Paul 75 L82's Avatar
I would try a little thicker oil and see how it sounds.
Old 04-26-2012, 02:55 PM
sfc rick's Avatar
I'll still change to 10-40 mobile one in the next day or two.
