Ls1 rebuild
Old 05-04-2012, 09:17 AM
JARM35's Avatar
Default Ls1 rebuild
I spun a rod bearing on my ls1. The crank is trashed. Can i get away with just replacing the crank, bearing and rod without having to take the block to a machine shop? Does anyone have an idea on what my have caused this to happen and what i can do to prevent this from happening again? Thanks
Old 05-04-2012, 09:55 AM
mark21742's Avatar
Did you lose oil pressure before it happened? How were you driving it just before it happened?
Old 05-04-2012, 11:35 AM
JARM35's Avatar
Not sure what the oil pressure was but I was almost WOT in fourth when it happened
Old 05-04-2012, 01:12 PM
PREDATOR-Z's Avatar
Get away, yes it is doable. Will it last? How long Who knows!
What you are describing is a band aid and not proper mechanical protocol. Some poeple might do something like that to patch a car before sale.
Spinning a rod bearing like that needs proper rebuild.
Old 05-04-2012, 01:46 PM
boostit5.3's Avatar
i might last it might blow the next day. i would do the full rebuild no telling how much bearing material went into the motor..
