I have 6 grand, LS1 or LT1?
Ive heard a little good and bad from both fbodys.
For the LS1 i know it's famous for having a weak block. And not being able to hand or pressure unless it's involved in the top end.
For the LT1 i know it has substantial torque but lacks a little high end, but nothing some bolt ons can't fix.
Anyone?
Anyone?
Anyone?
Anyone?
An LS motor is going to be stronger in stock form and handles bolt ons just as well, if not better. Not trying to start any sort of LT V LS butthurt session just stating facts.
In before the butthurt.
The LS motors are superior in every way compared to the LT1, which is basically just a sbc. Pull the oil pan off both motors and tell me which bottom end is stouter. There is no comparison.
Ls1 have 6 bolt mains. They are very strong. Gear driven oil pump under the timing chain cover, can write a page of great things about the ls1. There's guys on the Corvette forum with 400,000 plus miles on their motors. They respond better to mods. And don't forget lighter. And no crappy opti spark.
Like other said, I'm not trying to put down the LT motor, GM just advanced the technology.
LS1, the blocks arent weak? im not sure why youve heard that! they do have less bottom end torque than the lt motor but they are a superior design.
They actually have more bottom end torque, the lt1 just reaches peak torque at a lower rpm..... Jussayin
The motor will be going into a former 3800 Camaro. Anyway. here's my pros and cons of both
LT1 PROS:
Sound
Torque
Block strength
Cooling system
Price
LT1 CONS:
Optispark
Gas mileage
LS1 PROS:
More valve pressure release action
Handles nos better but i won't use nos.
How do you guys figure the LS1 is much better choice?
Also i want to stroke the LT1 to a 454.
LT1 PROS:
Sound
Torque
Block strength
Cooling system
Price
LT1 CONS:
Optispark
Gas mileage
LS1 PROS:
Well first off do you know all it takes to change out a v6 to v8 car it takes a lot thats what I was going to do until I realized all the **** you have to do. An ls1 will be better all around and yea opti sucks lol. ls1 will have more aftermarket for it.
Also lt1 to 454 I'm pretty sure cant be done correct me if I'm wrong ?
But I would really reconsider because half your budget will go into things for the swap. Let alone if you still need to pass emissions !
