ls1 spun rod bearing , rebuild advice
hello, I recently spun my rod bearing and looking to rebuild my stock ls1. I have a TSP v2 torquer cam ,ls6 intake, off road pipe with magnaflow exhaust, stock heads. The machine shop said the crankshaft cannot be safed. I'm looking at rotating assembly and there pretty pricy. I just want to put stronger internals for nitrous. Would a rebuild crankshaft kit be ok or should i put a new crank or need a forged unit?
Hey, Pow-Low,
Windsor, here.
I've just gone through the same thing.
Whether you need a forged unit or not prob depends on how much spray you're going to use with your combo.
I don't have the experience to tell you at what threshold this would happen, but I'm sure that someone will chime in to help.
You might check out the Classified section for good used cranks, or maybe a bottom end.
Also, I found a used OEM crank on ebay for cheap.
Good Luck!
Windsor, here.
Good Luck!
how bad did the rod eat into the crankshaft? you can cut/turn the crankshaft quite a bit, as much as .030" (if my memory serves me correctly). You need to have the crank Nitrated after you cut it to restore the hardness. Not sure how much a stock replacment crank goes for but Nitrating and turning the crank will run you $200-$300
I swear taking you off ignore has made this board funnier than a comic strip.
UNDER PRESSURE MOD
I have my stock crank that's in good condition if you're interested. The only reason I didn't reuse it for my build was the crank pulley spun on the snout, so it's buggered up a little bit. If you're not going to run a supercharger, it's not really an issue though.
Let me know if you're interested and I can get you pictures.
thanks for the info guys, as far as rebuilding my stock crank i guess i spun more than one bearing? I called back today and actually talked to the machinest. He said the extra pressure from using nitrous on a rebuild crank isn't a good idea and forged would be better. I think its a good point . I just have to stop being cheap and bite the bullet.
