Can you swap reluctor wheels?
Like title says, can you change the reluctor wheel on the ls cranks? I bought a 2005 lq9 and was planning on building a 408, but now to save money might build a 370 instead reusing stock crank. Since it has 58 tooth wheel, can i have that replaced with a 24x so everything works properly with out needing any other parts?
If you can replace them, where would i get a 24x one? Also how do you install it so the teeth are in the correct position so the computer knows the correct angle of the crank?
LS1Tech Premium Sponsor
Goodson makes the tool that we prefer and use in our machine shop to align/install wheels correctly!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I have another question about this reluctor wheel. I don't physically have it in front of me and i never counted the teeth, was just assuming it was 58x. The engine is a 2005 lq9, or so i was told. So it is still a gen 3 engine. Wouldn't htis have the 24x reluctor wheel? cause it doesn't have any timing pickup in the front cam cover.
I'm new to ls engines, but this crank had what looked like two rings on it. Is this how it should look? I'm looking to see if anyone knows are all lq9/lq4's no matter what year a 24x crank?
