how do you know if you have the OEM stronger rod bolts
Old 06-21-2012, 08:31 AM
vbls's Avatar
Default how do you know if you have the OEM stronger rod bolts
ok i was told that some year 2000 cars have stronger rod bolts than the 98 and 99. how would i tell which i have?
Old 06-21-2012, 11:36 AM
badazz81z28's Avatar
I don't think it really matters. If you "need" stronger rod bolts, you might as well swap them out for ARP...I'm skeptical about Katech.
Old 06-21-2012, 05:43 PM
PREDATOR-Z's Avatar
ARP needs rod resizing, Katech are same design as stock but higher tensile strength.
Old 06-21-2012, 07:05 PM
john563's Avatar
ive had katechs in mine for bout 5 years now.
Old 06-21-2012, 07:12 PM
Yes, ARP bolts require re-sizing, Thats why I wonder about Katech. How do they provide a stronger bolt (better clamping), would require more stretch because of higher tensile, yet don't require resizing?
Doesnt make sense to me.
Old 06-21-2012, 10:00 PM
chrisfrost's Avatar
To answer You're question the first design bolts have a smooth straight shaft that is a little narrower than the second design bolts and the first design bolts use an insert that goes into the rod and they are a little longer . The second design bolts are a little fatter with what looks a little similar to the Wave-Lock ARP bolts on the shaft and they are a little shorter overall and the threads are a little shorter than the threads on the first design . Personally I kinda like the ARP bolts because they not only are stronger but they are longer going all the way into the threads on the rod making the rod a little stronger at the big end . But the stock bolts are good safely to between 400-450 whp and 6200rpm's . Oh ya the first design bolts the diameter of the shaft is a little smaller than the threads and the second design the shaft is the same diameter as the threads .
Old 06-21-2012, 10:43 PM
Do you happen to have any pics?
Old 06-21-2012, 10:46 PM
moeZ28's Avatar
I have always doubted that there is any real difference with the stock rod bolts from year to year. I bought my 98 Z28 with 71,000 miles, went through 3 different cams and bolt ons, and cranked it to 6800 with the last two cams for over 40,000 miles, and it blew a head gasket at 147,000 miles...bottom end was solid!
Old 06-22-2012, 06:24 PM
Camaro99SS's Avatar
Only the 01+ cars have the stronger rod bolts because of the C5 Z06 having a higher redline and rev limiter (6750) while still having warranties to honor.
That said I tend to agree with moe above. Shoot there are 2 bolt LT1 guys who have been spinning their shortblocks to almost 7000, and they hold up for a reasonable amount of time. If those can, any LS1 certainly can survive 6800 just fine! I'd worry more about a good tune.
Jason
Old 06-23-2012, 08:19 AM
98SSClone's Avatar
My LQ4 in my Camaro still has the stock bottom end, including hardware. I spin it to 6800 regularly. Hasn't missed a beat yet, however, mine is a '07 model.
Old 06-23-2012, 02:45 PM
5w20's Avatar
something not to worry about. you want some good rod bolts, buy Katech.
Old 06-23-2012, 09:42 PM
cartel's Avatar
who sells katech?
i dont see them on summit-- and i noticed on the ws6 page they sell ARP rod bolts..
ARP are $150 how much are the katech?
Old 06-24-2012, 05:02 PM
moeZ28's Avatar
Katech is a sponsor on here...they sell Katech rod bolts.
Old 06-24-2012, 05:55 PM
5w20's Avatar
http://store.katechengines.com/conne...bolts-p25.aspx
Old 06-25-2012, 12:53 AM
cartel's Avatar
thanks-- now to decide which one to buy..
Quick Reply: how do you know if you have the OEM stronger rod bolts
