Fair price for hotcam & LS6 springs?
I have a 2000 TA with the mods listed in my sig. A friend of mine has a hotcam and set of LS6 springs that have never been used. As I am currently on a tight budget I thought these would make a decent addition to the car until I can afford a good set of heads and matching cam. What are you guys opinion as to the value of these items? Thanks!
used OEM springs..LOL. IF money is that tight then wait and save a bit more and at least get a set of new ones.. Call Scoggin Dickey for them and get a good price..
Offer $75 shipped.. the hot cam is all over the place.. they are literally a dime a dozen and there are better choices
I'm also assuming I should probably replace the oil pump, timing chain and push rods while I'm at it.
Hotcam - 12480033
Front cover gasket - 12558013
Crank seal - 12561244
2x Water pump gaskets - 12559271
New crank bolt - 12557840
2x Valve cover gaskets - 12560696
8x LS6 spring seats - 12565118
16x New spring locks - 10166345 (I think, didn't have a number on the package)
16x LS6 Springs (blue) - 12565117
And these are the all the parts that I believe I will need to complete the swap. Am I missing anything?
3 arm pulley puller - local auto store
5/16" dowels to hold up lifters - local hardware store
Valve spring compressor tool
Kent-Moore flywheel holding tool - J-42386-A - various online tool places
Valve Stem seals intake - 12533586
Valve stem seals exhaust - 12457652
Spring retainers - 10166344 - lowest price so far I found at pace performance
LS2 timing chain - 12586482
Ported LS6 oil pump with new o-ring
Cylinder leak-down tester kit - found one cheap at HFT
