So Vengeance stopped carrying Yella Terras 6645's because of increased failure??
Old 07-02-2012, 03:05 PM
need4z's Avatar
Default So Vengeance stopped carrying Yella Terras 6645's because of increased failure??
So I just ordered a set of YT 6645 for my TFS 215 heads and now I have been reading on this and the corvette forum about more and more of these rockers breaking. WTF.. I dunno anymore.. what is fail safe beyond spending big bucks on a jesel setup when you need a full roller thats light at the valve tip?
Old 07-02-2012, 04:06 PM
3pedals's Avatar
A fellow Winnipegger!
The stock rockers seem to be the best - especially with a cam with less than .625" lift. The crappy thing is if your TFS heads have bronze valve guides, they will wear FAST if using the oem rockers.
If you are set on using the TFS heads, get the guides changed to factory GM style guide material, and you should be set.
Barrett
Old 07-02-2012, 04:25 PM
Frans96SS's Avatar
We have been using the comps.
Old 07-02-2012, 05:30 PM
need4z's Avatar
hey 3 Pedals. Thanks for the suggestion. Been there done that with stock rockers and shims..they dont work. Motor is assembled and Im not taking my heads off to send in for guide change. lol.. When the funds are available I will be getting the comp shaft setup!
Old 07-02-2012, 05:36 PM
3pedals's Avatar
you ever run that thing at Gimli?
Old 07-02-2012, 05:39 PM
need4z's Avatar
Not big into drag racing anymore.. I guess you do though huh? lol Id kill to have a decent road course track here.
Old 07-02-2012, 05:44 PM
3pedals's Avatar
ya, not much for road stuff around here, although not to far south of the border....lol
Im not even sure if there are any auto-x events anymore? pretty sad around Winnipeg
Old 07-02-2012, 08:21 PM
Turd Gen Guy
1nasty86's Avatar
Trunion upgraded stock rockers here and no problems.... Only think like stated above youd need powder metal valve guides or the stock rockers will eat the bronze ones up
Old 07-02-2012, 11:25 PM
need4z's Avatar
Thanks pal. Im way beyond that basic info now. Knew that months ago. lol.. Thanks anyway. Im researching rockers other than the avg. run of the mill HS or YT that can actually handle heavier open spring pressures.
Old 07-02-2012, 11:31 PM
Detoxx03's Avatar
I haven't heard of many stock rockers failing.
Old 07-03-2012, 12:11 AM
sepsis's Avatar
Comp cams or Crane.
Old 07-03-2012, 12:24 AM
Silver408z's Avatar
They do and that is part of the reason why the trunion upgrade was developed
Old 07-03-2012, 12:40 AM
TransAmcoupe98's Avatar
Biggest thing the trunion upgrade does is eliminate the needle bearings. So in the event the rocker fails, needles don't go through your motor. Needle bearings are sorta like AIDS for your motor. Might not kill it initially, but it will die in time. Stock rockers have been failing because people are using a much stiffer spring these days such as the PRC .650 or .675, and using higher lift cams. This eventually will break the tip off and what is causing a lot of failure. THe comp or Jesel are great choices for aftermarket. Yella terra or Skorpion are...ehhh.
Old 07-03-2012, 01:39 AM
c5z16z's Avatar
Are these the COMPS you are recommending http://texas-speed.com/p-1219-comp-c...1-rockers.aspx,
also what JESSEL ROCKERS would you recommend?
Old 07-03-2012, 02:22 AM
Yes, those are the Comp rockers. Below is the link to Jesel's.
http://www.speedinc.com/cont.cfm?cid=C0000618
Old 07-03-2012, 03:09 AM
derrickman05's Avatar
I was at Texas Speed today ordering a top end and when I asked them about a rocker they said nothing beats a stocker with a trunion upgrade. (for what I'm trying to do) I'm sure a 1000$ set of jessels would be just fine but I got upgraded rockers for 1/3 of that
Old 07-03-2012, 03:13 AM
Thats the dumbest thing Ive ever heard come from a sponsor...
Old 07-03-2012, 03:16 AM
Stockers will hold for a little while but they are not made to, even with a trunion upgrade. It doesn't strengthen the entire rocker. The tip is what is most prone to breakage with today's aggressive cam lobes, spring opening pressure, etc. Try a search on broken rockers and make the decision yourself.
Old 07-03-2012, 03:17 AM
lemons12's Avatar
What cam?
Depending on that plenty of rockers would beat factory... It will wear the tip of the rocker out (might not even be on the tip) and will shift side to side.
Old 07-03-2012, 03:23 AM
lemons12's Avatar
Also you didn't get "upgraded rockers"... You got an upgrade to your rockers so that when they fail they won't wreak havoc on everything.
Quick Reply: So Vengeance stopped carrying Yella Terras 6645's because of increased failure??
