TSP 231/237 Peak Power...What RPM?
Old 04-01-2004, 04:55 PM
master of the "jack"stand
ChevyWeatherman's Avatar
Default TSP 231/237 Peak Power...What RPM?
I am wondering at what rpm you guys are seeing this cam make peak HP. I will have this cam on stock heads with full bolt ons. I am just guaging how much to tell the tuner to spin it during the dyno tune.
Thanks.
Old 04-01-2004, 05:25 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
When I had a catback setup, it peaked at 6250 and held the peak 'till 6700rpms.
Old 04-01-2004, 05:30 PM
goinbroke's Avatar
Mine was still climbing at 6500.
Old 04-01-2004, 05:40 PM
00blkws6's Avatar
I'd spin it to right at 7K. Mine peaked after 6K but I can't remember the exact number off the top of my head.
Old 04-01-2004, 07:37 PM
LS1TECH Sponsor
foff667's Avatar
most peak at around 6300 but there have been some that peaked higher...jason said they might have been ground wrong from the cam maker...its got 2 degrees of advance ground in so thats why it isnt supposed to peak at some off the wall #.
Old 04-01-2004, 08:28 PM
Ragtop 99's Avatar
6600 is the max that I would spin a stock bottom end.
Old 04-01-2004, 08:39 PM
gomer's Avatar
When I was running that cam it peaked at 6300, shiftlight at 6600, rev limit at 6800. If I wasn't careful it would pull right into the 6800 limiter. That cam pulls hard.
Old 04-01-2004, 09:47 PM
Navy David SS's Avatar
With my PP II heads and the 231/237 mine peaked right at 5800-5900 and held almost steady until red-line at 6800.
David
Old 04-01-2004, 10:27 PM
I am planning on having the limiter set at 6800, shift light at 6600. You guys don't think occassional 6600-6800 action is going to hurt the stock bottom end do you? I go to the track maybe 5 times per year...the bottom end has 7k miles.
Old 04-01-2004, 10:54 PM
Chicago Crew UnderBoss's Avatar
YOU Shoud be fine but just don't plan on living at 6600plus!!!
Old 04-01-2004, 11:11 PM
98_1LE's Avatar
I have had the limiter at 6600 for the past 18K miles in my car. I run the car hard at open track events on a road course, and last weekend the motor developed a serious rod knock. I suspect a stretched rod bolt is the culprit. I would at least put good rod bolts in for anything past 6400.
Old 04-02-2004, 12:49 AM
SoloSport's Avatar
What if I just have a cam? Is that okay to run past 6600 RPM?
