tsp 233/239-.595/.603 cam question
Old 07-18-2012, 10:07 PM
nitroussharks's Avatar
Default tsp 233/239-.595/.603 cam question
i am going to put this cam in a 2000 camaro z28 with bolt ons and ls6 intake
my question is what pushrod do i need ,7.4 or ? it has stock heads
also what would be a good injector size 42lbs or ?
Old 07-18-2012, 10:56 PM
chevybayboy's Avatar
I think you have to measure to see which rods you need
Old 07-19-2012, 09:00 AM
I got the pushrod checking tool but not sure how to check them,anyone have a link to this
Old 07-19-2012, 09:39 AM
Mike Morris's Avatar
http://forums.corvetteforum.com/c5-t...ow-to-use.html
Old 07-19-2012, 10:25 AM
3rdCoastPowerSports's Avatar
still measure but i have run your set up before. With stock MLS gasket 7.400- 7.425 PR depending on where you want your preload to be. Off the top of my head i want to say the 7.400 PR was at .060" preload and 7.425 was .025" more than that. The car will run with the the 26lbs injectors but they will be at the end of there duty cycle. 36lbs injectors is what i would put in it
Old 07-20-2012, 06:45 AM
Anymore input
Old 07-21-2012, 10:45 AM
dodson55's Avatar
if you are running stock heads and gaskets you can use a 7.4 pushrod and should be around the .075-.080 preload range 42 injectors will be more then big enough a set of 30lb red top svo injectors will be more then enough for you they will be 36lb at ls fuel pressure
Old 07-24-2012, 09:27 AM
LS1-450's Avatar
Originally Posted by nitroussharks
Anymore input
Really need to measure. Nice cam, BTW
Old 07-25-2012, 02:21 AM
I Confederate I's Avatar
I have this exact cam in my 01 SS. Ls1 with bolt ons. TSP recommends 7.400 in. pr's. I'm running 7.450 in. but recently had a lifter **** the bed. I'd stick with the 7.400's.
Old 07-25-2012, 09:50 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
TSP might have made an educated guess at your combo for 7.400's, but we always recommend measuring before installing any length for any combo!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-25-2012, 03:49 PM
confederate sorry to hear that,i got some 7.4s with my cam but i will try to measure to be sure,what kind of power did that cam make,any hp numbers or track times
Quick Reply: tsp 233/239-.595/.603 cam question
