wot smoke
Old 07-23-2012, 12:24 AM
johnny89345's Avatar
Default wot smoke
Randomly when i get on it I have been told my car smokes out the exhaust. I have noticed it for the first time tonight. The motor has only 70k on it and seems like it runs strong. One thing it does do fhat is probaly the prob is suck a lot of oil through the ls6 pcv. I do have some pressure in the crank case though. What should I test for? I was planning on h/c soon but if the motors shot is rather not waste my noney
Old 07-23-2012, 12:53 AM
sepsis's Avatar
Compression and leak-down testing is in order.
Old 07-23-2012, 01:29 AM
69cutlassrkt's Avatar
Mine used to do that too and on start up. I had no pcv valve though and had the line still going to the intake from the passenger side head. The oil in the intake actually messed up my map sensor.
Old 07-23-2012, 09:19 AM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
Compression and leak-down tests are where I would start first as well. If everything is good, I would then look into a pcv setup, but my best guess says you will probably find something when testing.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 07-23-2012, 09:28 AM
HVYMTL's Avatar
What color and how much smoke? My wife told me the same thing after I went WOT down a back road a couple months ago. I freaked out and researched and found a ton of people have the same issue, as long as it's not billowing out in a big cloud. Mine just puffs a little bit of white/gray smoke at high rpms, or between redline shifts
Old 07-23-2012, 01:41 PM
It's never on start up and random. I have to rev it up near redline for it to happen and I can't tell the color of the smoke as it never happens. Imo its something with the pcv as my intake is soaked in oil literally. And i burn a lot of oil between oil change but ill do a leak down and conpression tn and let you guys know what i come up with. The car did sit for the last 5 years behind a building so it definitly could be valve seals. Also what's the proper way to do a leak down test?
Old 07-23-2012, 02:00 PM
Exidous's Avatar
Honestly, mines has done this ever since I swapped the motor into the RX-7. It's only when I really get on it at WOT. I have done leak-down and compression test and get about 155-160 across the board. I don't remember what the leak down results were but they weren't bad. You should still do the tests to make sure though.
To do a leakdown you need a compressor and a leakdown tool. You pump a specific psi into the chamber at TDC(if memory serves) on the compression stroke and the gauge will tell you the % of air that is leaking.
If you are running a little rich it could be carbon build-up freeing itself out of the exhaust. My passenger bank was running a tad rich due to injector imbalance and the cat was black whereas the cat on the driver side was clean.
Old 07-23-2012, 05:48 PM
i have no cats, egr, or emmissions equiptment in the car if that makes any difference. i tried to use the compression tester you rent from auto zone on two cylinders, neither one would rise up past 30psi or hold any pressure at all. i think the guage might have been bad. and both plugs had a greyish build up on them.
Old 07-24-2012, 01:49 AM
Exidous's Avatar
Try a couple more cylinders. 30psi is certainly off.
Old 07-24-2012, 02:12 AM
intenseblue's Avatar
Just had this same issue. Turned out a rocker bolt had backed out and was not opening the intake valve. Had no noise from being loose and created zero damage. Took about ten minutes to fix. Car felt like it picked up 75whp.
Old 07-26-2012, 11:46 AM
I've been meaning to check my rockers. 22ft/lbs correct. That would be fantastic and I have noticed a loss in power in the last year.
Old 07-27-2012, 03:12 AM
White6SpdZ28's Avatar
I had the same issue, turned out one of my wires was on all the way yea felt dumb on that one.
Old 08-04-2012, 06:26 PM
Rockers are fine. But I did notice the thread to #1 spark plug was soaked in oil? The tip itself wasn't wet though just the threads completely drenched
Old 08-05-2012, 01:03 AM
99Bluz28's Avatar
Check your valve seal.
Old 08-05-2012, 04:27 AM
The Scammer Hammer
dr_whigham's Avatar
^^ That was going to be my first suggestion as well.
Old 08-11-2012, 12:59 PM
Something else I forgot to mention the inside of the exhaust and near each exhaust flange its soaked and solid black. And all the plugs are clean. So its gotta be a vlave guild or seal on one of the exhaust valves. I couldnt do a compression test, Idk how the hell I'm supposed to screw that line in it seems like its physically impossible
Quick Reply: wot smoke
