402/8 budget built for boost
Old 07-25-2012, 01:10 PM
Jadedbird's Avatar
Default 402/8 budget built for boost
So I am kicking around the idea of a 402 or 408 built for a f1a
i need some ideas tho. what did you go with?
did you pull a 6.0 out of a truck and work the 317 heads and forge the internals or did you order from tsp or some where. being a budget i would think that a salvage yard would be the route to go.
what internals did you go with
what heads and cam and intake did you use?
does it matter if it was a 2wd or 4wd truck?
what all do i need to swap from my ls1?
pictures and dyno charts and time sheets would be nice just to make me drool
Old 07-25-2012, 02:30 PM
mark21742's Avatar
03 6.0 truck block here punched and stroked ro 408 with fully forged bottom end.
Eagle crank and H-beam rods
Mahle pistons
King bearings
I'm running 12.5:1 compression with potted 241 heads milled to 57cc chambers.
In your case since you want to go FI is just do a quick clean up mill on 317's port them and maybe do a little clean up in the chambers.
Old 07-25-2012, 04:03 PM
Jadedbird's Avatar
Mahle pistons
King bearings
nice! got any times or numbers yet?
Old 07-25-2012, 05:03 PM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
What are you putting it in, what kind of power are you trying to make, and is weight an issue?
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 07-25-2012, 07:27 PM
Jadedbird's Avatar
Well id like to be putting down 500-600. Of course it shouldnt be a problem with f1a and a 402/408 iron block.
Something streetable that isnt anything to laugh at on the strip. Id like to see 10s at full weight
Old 07-25-2012, 07:54 PM
mark21742's Avatar
Trying to finish up m tube chassis 04 GTO build now...hope to have it finished before the season is over
Old 07-25-2012, 09:56 PM
Jadedbird's Avatar
Nice! Ill keep an eye out for your results!
Old 07-26-2012, 12:26 AM
usmcpi's Avatar
Mahle pistons
King bearings
How much was your stroker kit plus any other costs like block prep/machine work, etc? Looking into a budget 408 build currently.
Old 07-26-2012, 06:19 AM
mark21742's Avatar
Honestly if you figure every little thing in including the port work (that I did ) and machine work I'm probably in for close to $8,000-$9,000 throttle body to oil pan
Old 07-26-2012, 08:22 AM
Jadedbird's Avatar
Im hoping to find a cheap lq4 or maybe even trade my ls1 for a lq4
Old 07-26-2012, 09:02 AM
If it were mine, and on a budget, I would do an Iron 402. That way you could keep the strength of the thicker cylinder wall and just turn up the boost...
__________________
Old 07-26-2012, 10:05 AM
Jadedbird's Avatar
whats a good price that you can do for me on a 402 jake?
Quick Reply: 402/8 budget built for boost
