low to mid range cam that works on zo6 springs??
okay im about to start my engine build and going stock bottom end, 5.3 ported heads, zo6 springs .550, Ls6 intake, and becuase this is in a s-10 truck i cant run headers, but will have true duals free flowing, i want a cam that makes low to mid range power on the A4 trans, also i plan on adding nos system in the future.
thanks for any input anyone has!
Originally Posted by PREDATOR-Z
I bought a 216/220 Comp and they told me 2002 Z06 springs would work. Basicaly you want to stay in the 230 lift range on the cam.
okay iv been reading and im thanking of going with the TR220 or is there a better cam with more low end power thats easy on the springs than the TR220?
Originally Posted by SouthFL.02.SS
I wouldn't run a TR220 on LS6 springs. Just my 2 cents.
The Comp 216/220 looks like a good cam for ya.
y can't u run headers? my friend has headers on his '55 with an LS1 in it... they were custom made, but y wouldn't a set of camaro long tubes work on an S10? i would use the 212/218-.522/.527-114 cam in an S10, with a converter around 26-2800, depending on the weight of the truck... the smaller cam won't need any tuning, where the bigger cams will need some...
Originally Posted by sr_ryan1
i read that the 216/220 missfires on the A4's
!LS1 11 Second Club
Originally Posted by 11 Bravo
I would try the GM ASA cam. .525 lift with big duration.
The COMP Xtreme 216/220 .525/.532 114 seems to be the cam to go with in this case, but then again, I would do everything possible to get some headers on that thing to go with a bigger cam.
The ASA came to mind also, but if he's sticking with stock exhaust manifolds, I don't see the ASA being good for his application.
okay i still wanna try the TR 220/220 on zo6 springs im not going to be reving to high.
That is a really bad idea. Maybe you should call Thunder Racing before you try that.
You know you should spend the $150 bucks for the 918 springs...best case you're going to be out a valve or two, a piston or two and a lot of labor when you learn why not to use LS6 springs with a TR220.
If you have to use LS6 springs, the Hot Cam is the biggest cam you can safely use.
