Opinion on LS1 block imperfections before reassembly
I'm about to reassemble my LS1 and while inspecting the block I notice quite a few rough/sharp edges in the water and oil passages from the factory casting process. Is it beneficial to smooth these out some or is it not worth the trouble? Thanks
Closed ex-Sponsor Account
you bring up a critical topic; inspecting the oil galley/passages, without the hex plugs out/the barbell/and the front metal plug, your not going to get things properly cleaned from the machine shop
Measurements and cleanliness are the BASIC's prior to any engine assembly(don't quote me here as I don't build LS motors daily).............but I have seen a block come back from the machine shop 'cleaned' only to remove an oil galley plug with shavings behind it
Study the oil passages, what path the oil takes...........only oil that hits the filter is the oil being sucked up the p/u tube thru the pump and into the filter, anything else could be headed right to the main's
You might have misunderstood my question. I was just noticing some rough edges that I'm sure are on every block because of the GM casting process. I was wondering if I would be alright to pass my dremel over some of them to smooth out the flow somewhat?
