Do Patriot dual springs require Comp r lifters?
This spring has been used with cams as large as .638 valve lift with no problems.They are made out of the best materials possible.The manufacturing process is the same as pro stock drag springs.The springs are designed to last everyday with a .650 lift cam.They have 135lbs on the seat and 380lbs open.This is the best spring on the market IMO.
