Timing Chain/gear replacment
Old 08-23-2012, 03:58 AM
DisasterpeaceWS6's Avatar
Default Timing Chain/gear replacment
Upgrading cam and heads. Car has 89,XXX miles think I should replace/upgrade timing chain and gear also or the old one still usable?
Old 08-23-2012, 04:20 AM
vettenuts's Avatar
Personally with high mileage I like to replace the set because the sprockets will wear and tend to wrap the chain more. The set is not that expensive so I would go that route myself.
Old 08-23-2012, 04:23 AM
Ok. Do I need to get a proformance set or can i just got to the dealer and get a stock set? Because I am doing the install tomorrow and it will takes a few days to get the set in the mail.
Old 08-24-2012, 06:48 AM
Undertow74's Avatar
LS1Tech 10 Year
look up Yank in the parts classifieds. can get the whole set with LS2 chain cheap. FYI will need a 3 jaw puller that has deep fingers on it to pull the crank sprocket off. the one i had the fingers didnt have enough bit to them and would slip off the sprocket.
Old 08-24-2012, 07:09 AM
garygnu's Avatar
a ls2 set from a dealer will work fine.
Old 08-24-2012, 03:15 PM
So go to dealer and get an LS2 timing chain/gear set? That would replace stock one from an LS1? Same fit?
Old 08-24-2012, 03:18 PM
Undertow74's Avatar
LS1Tech 10 Year
yes, or order online from Yank in the parts classifieds and save some money, your call
Old 08-24-2012, 03:52 PM
batboy's Avatar
You want a LS1 timing set. It'll have the LS2 chain, because GM don't make the old wimpy LS1 chain anymore.
Old 08-24-2012, 05:19 PM
Ok thanks guys. I'll look into it.
Old 11-05-2012, 09:23 AM
fbodlovr's Avatar
I know this post is a few months old, but I am curious to know if anyone has any instructions on how to replace the timing chain. I have been looking and can't find anything. And trust me, I always search first. I thought this was relevant to the original poster. I replaced my water pump a couple months ago, and I'm wondering if it should have been done then if there isn't much work involved beyond that point. Any help would be appreciated.
Old 11-05-2012, 09:40 AM
elephantrider's Avatar
yes, you should have replaced the timing chain when you did the water pump.
it will all have to come off again...
Old 11-05-2012, 09:51 AM
fbodlovr's Avatar
Yeah, I figured. At least it isn't too terrible taking the water pump off. Are there instructions somewhere explaining how exactly to do the timing chain/gear replacement?
Old 11-05-2012, 10:19 AM
The Scammer Hammer
dr_whigham's Avatar
Scan through this and figure out what parts pertain to you.
http://ls1howto.com/index.php?article=23
Quick Reply: Timing Chain/gear replacment
