227/235 lsr cam on 243 headed lq4?
heads have had the bowls blended, valve job, and pockets ported..
would this cam be optimal for my lq4? heads are not milled and i can get this cam for $250 from a guy who had it laying around after selling his ls3 block. The lobes are in real good shape (ran it for 3k miles) and none of the lobes are pitted or anything.
he's also got a 233/239 cam as well but i figure that's not tame enough for a "street driven car"
keep in mind i've had a few cammed vehicles, i know what to expect, would this cam be bearable? i'm planning on running a yank 3600 and a decent sized Oil cooler from where i work.
i have a summit link to the same cam (this part number is engraved on the cam) it's 113lsa so im not sure about the icl
http://www.summitracing.com/parts/CCA-54-458-11/
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 1,900-7,000
Intake Duration at 050 inch Lift 227
Exhaust Duration at 050 inch Lift 235
Duration at 050 inch Lift 227 int./235 exh.
Advertised Intake Duration 277
Advertised Exhaust Duration 285
Advertised Duration 277 int./285 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.614 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.621 in.
Valve Lift with Factory Rocker Arm Ratio 0.614 int./0.621 exh.
Lobe Separation (degrees) 113
Camshaft Gear Attachment 3-bolt
Install it on a 110 ICL.
Not speaking directly to you when I say this, but this is something I see a lot that needs to be addressed.
Guys when you're buying aftermarket camshafts they are purposely meant to be used at their set valve events they are specified with.
When you do not degree a cam you are nearly guaranteeing that you will not be using those specified events and therefore not utilizing to the fullest what that cam can do for your application.
To not degree a cam is like not smelling school cafeteria food before putting it into your mouth. You might end up not liking what you shovel into your mouth if you don't check to see if you like the smell of it first.
Sounds like Russ is familiar with this cam and that has advance ground into it already. If that is the case then install it straight up dot to dot, but STILL degree it!
Timing sets can and will be off and it happens way more than most people think it does.
