Predator-Z El Torro Cam
Old 09-04-2012, 05:20 PM
BTLFEDSS's Avatar
Default Predator-Z El Torro Cam
Was looking at your 230/230
Wondering how this would work for my cam only set
LS6 or FAST 90
LT's
UD Pulley
4000 stall
4.30's
28" tires
3500 pounds
Looking to run in the 11's
These are the numbers needed to order
Intake lobe # 3016R
Exhaust lobe # 3725R
111 LSA
109 ICL
Also what springs to use with it??
Run a 7.4 pushrod
Old 09-04-2012, 11:11 PM
spicebird98's Avatar
you should be running 11.90's with that setup in decent air WITHOUT the cam.
Old 09-04-2012, 11:14 PM
Turd Gen Guy
1nasty86's Avatar
why not do a exhaust favored split like a 230/236? everyone knows ls motor can inhale alot easier than they can exhale..
Old 09-04-2012, 11:46 PM
PREDATOR-Z's Avatar
LS6 or FAST 90
LT's
UD Pulley
4000 stall
4.30's
28" tires
3500 pounds
Intake lobe # 3016R
111 LSA
109 ICL
Run a 7.4 pushrod
Springs: Comp cam 921s or similar (I run mine on PSI 1511, I like it light, titanium retainers)
Pushrods will have to be measured.
Old 09-05-2012, 12:52 PM
14k
14k's Avatar
I'm interested in the toro too. But I'll be running a ss3600 3.23s ls6 mani and p/p 241s.
I'm planning on running a tsp 370 later how would this cam perform in said 370?
Old 09-05-2012, 07:23 PM
Golf&GM's Avatar
What's the lift on this cam?
Old 09-05-2012, 10:02 PM
99Bluz28's Avatar
XFI 230 intake lobe .612" lift, and a XER 230 exhaust lobe .592" lift.
Old 09-06-2012, 08:05 AM
Sales@Tick's Avatar
A lot of people are scared of an early EVO and exhaust duration.
Old 09-06-2012, 12:43 PM
PREDATOR-Z's Avatar
There is more to a power-curve than just a percentage of intake flow. One has to observe what all the valve events do for each other and what is the result of that symbiosis in the power-curve. Highest peak hp does not necessarily mean quickest.
Quick Reply: Predator-Z El Torro Cam
